Test & Tools
Test & Tools
Blog Comparison of Sensor Types
  • Author Author: lab1971
  • Date Created: 13 Mar 2019 12:43 PM Date Created
  • Views 660 views
  • sensor + test
  • platinum resistance thermometer
  • accuracy
  • mi thermocouple
  • thermocouple
  • thermistor
  • comparison of sensor types
  • sensor
lab1971
lab1971
13 Mar 2019
Platinum Resistance Thermometer
Thermocouple
Thermistor
Sensor
Platinum-wire wound or flat-film resistor
Thermo-element, two dissimilar metals/ alloys
Ceramic (metal oxides)
Accuracy (typical values)
0.1 to 1.0°C
0.5 to 5.0°C
0.1 to 1.5°C
Long term Stability
Excellent
Variable, Prone to ageing
Good
Temperature range
-200 to 650°C
-200 to 1750°C
-100 to 300°C
Thermal response
Wirewound – slow
Film – faster
1-50 secs typical
Sheathed – slow Exposed tip – fast 0.1 to 10 secs typical
generally fast 0.05 to 2.5 secs typical
Excitation
Constant current required
None
None
Characteristic
PTC resistance
Thermovoltage
NTC resistance (some are PTC)
Linearity
Fairly linear
Most types
non-linear
Exponential
Lead resistance effect
3 & 4 wire – low
2 wire – high
Short cable runs satisfactory
Low
Electrical “pick-up”
Rarely
susceptible
susceptible
Not susceptible
Interface
Bridge 2,3 or 4 wire
Potentiometric input. Cold junction compensation required
2 wire resistance
Vibration effects/
shock
wirewound – not suitable
Film – good
Mineral insulated types suitable
Suitable
Output/ characteristic
approx. 0.4 W/°C
From 10µV/°C to 40µV/°C depending
on type
-4% / °C
Extension Leads
Copper
Compensating cable
Copper
Cost
Wirewound – more expensive
Film – cheaper
Relatively low cost
Inexpensive to moderate
Comments and values shown in this chart are generalised and nominal. They are not intended to be definitive but are stated for general guidance.
The information given shows average application experience, but some of the considerations can be modified by special design or selection.
    Jan Cumps over 7 years ago +1
    We have a dedicated area for Sensors . You are specialising in temperature sensors, correct?
