Test & Tools
Test & Tools
Blog DIY LAB Bench with Shelves
  • Author Author: Robert Peter Oakes
  • Date Created: 22 Sep 2014 2:23 PM Date Created
  • Views 4179 views
  • Comments 8 comments
  • tutorial
  • test
  • bench
  • diy
  • benches
  • lab
Robert Peter Oakes
Robert Peter Oakes
22 Sep 2014
How to build a low cost but large and very usable LAB Bench for your projects and test and measurement equipment
this total build was under 250$ including the shelving hardware, the cutting plans will included below once there drawn in a legible format
here is the video though to keep you going
And the Shelves
Cutting list
2 off 8 foot by 4 foot 3/4 plywood (Cut 2 * 6"*8' from one and 3 off 16"*8' on the other, table top = 3'*8')
1 off 8 foot by 2" by 6" poplar (cut to 88")
11 off 8 foot by 2" by 4" poplar (9 off 35", 4 off 28", 3 off 6', 3 off 2'
3 off 2' shelving runners
6 off shelving supports
pretty sure that's it, oh, and a box full of 2 or 2 1/2" number 8 screws (Deck Screws work Great)
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to shabaz +1
    Canada is famous for its maple syrup but I have not tried making my own yet Mixing it in a 30% / 70% ratio with Crown Royal I have done though... Mmmmmmmmm
    DAB over 12 years ago in reply to Robert Peter Oakes +1
    Hi Peter, I used to brew Mead and mixing it with maple syrup was ambrosia. I had not thought of mixing it with Crown Royal. I need a trip to the store. DAB
    Robert Peter Oakes over 12 years ago in reply to dragonstyne +1
    not too hard to make either Peter
    shabaz over 12 years ago
    Hi Peter,
    That's nice!!
    Where was the tea break like all good builders though : )
    I built a bench a couple of weeks ago so I've been there, but yours is a better finish. For the UK, I used the local B&Q garden centre, they have outdoor treated wood posts (for fences I suppose) that are about 90mm square cross-section (I only do metric : ). That made the legs, and and a load of hex nuts/bolts helped hold it all together, and for the top a combination of plywood for strength and
    covered with wood for finish.
    Mine was for the garage so it was smaller than the size of your bench though. If I was to do it again then either I'd find a better store (B&Q won't cut the posts, it has to be 225mm or more width) or I'd buy a table saw, and it would be useful in future too.
    My Garage is my wood working shop, I am fortunate to have the Table Saw and Routers, Compound Mitre saw etc to it was relatively easy to trim and cut the 2*4s
    the 8' * 4' ply wood though, I got the store to cut for me. We have a store called Home Depot (Canada/USA version of B&Q I guess) and they will do a few cuts for free then a small nominal charge for beyond that, so for instance, cutting the ply to 3' wide and the other to 16" shelf strips was all free.
    The ply has a real Maple finish on it too so I need to shellac it or Varnish before it gets stained by the coffee (I've been Canadianized image )
    shabaz over 12 years ago in reply to Robert Peter Oakes
    Ah! The right tools help : )
    mmm you shouldn't have said Maple, now all I can think about is maple syrup and french toast.
    Do you ever make your own maple or birch syrup? I hear that's quite popular to do if you're in the right location for it.
    Hi Peter,
