Test & Tools
Test & Tools
Blog Electronic Load Part 2
  • Author Author: waelect
  • Date Created: 1 Sep 2015 12:51 AM Date Created
  • Views 1451 views
  • electronic_load
waelect
waelect
1 Sep 2015
Hi Everyone,
I am really quite busy with a lot of setting up of the lab area. I hope to place a video of my changes in the lab work layout and my equipment shelf builds.
I have taken a small time out to place a video on my attempt at SPICE simulations on the electronic load all-be-it very simplified. I have not yet learn't how to create new component SPICE models on LT SPICE and MultiSIM blue (oops) but I at least have a simulation running. In the video I noticed the source series resistance will play an important role in building the circuit as internal resistance of some sources are very low. I will update the LT SPICE simulation to look at inputting more accurate source resistances to get a more accurate simulation. I will consider placing this in Part 3.
It is clear though after creating the video that internal propagation of voltages through the components play a big part in the overall performance. As for now as an experiment i will use easily available components and improve components later to reduce propagation as much as possible.
Anyway below is a video of my simulation exercise.
    Have used the Kikusui loads from Telonic very good spec, but not that cheap .Electronic loads
  • waelect
    waelect over 11 years ago in reply to jw0752
    Thanks John,
    I have actually identified another Simulation software and will add to the blog later. TINA is the software and it software and wider variety of SPICE model that I actually use.
    Malcolm
    jw0752 over 11 years ago
    Hi Malcolm,
    Thank you for the blog. I enjoyed your simulations for the load you are working on. I look forward to the video on your shop improvements.
