Test & Tools
Test & Tools
Blog How Many Chucks Would A Woodchuck Chuck?
  • Author Author: dougw
  • Date Created: 2 Jan 2024 3:55 AM Date Created
  • Views 2095 views
  • Likes 12 likes
  • Comments 10 comments
  • Mini chucks
dougw
dougw
2 Jan 2024
If a woodchuck could chuck chucks, how many chucks would a woodchuck chuck?
The curious case of mini chucks galore....
A little light tool blog - part of my new year's reorg activities ...
All my mini chucks are now in a designated container.
Do you have a favorite mini chuck and what do you use it for?
Now what about utility knives and glue guns?
    beacon_dave over 2 years ago
    That's a nice looking collection.
    I think I've currently only got tap lever mini chucks, unless you count Dremel type chucks.
    I'd quite like a micro lathe however and that would be an excellent excuse to accumulate more chucks.
    shabaz over 2 years ago in reply to beacon_dave
    It's worth checking out Arc Euro Trade for such tools, I didn't buy a lathe, but purchased my manual milling machine from there. It's been reliable for close to a decade (although I'm no power user of it, I do use it frequently). Their machines are Chinese, and they check them (and I believe UK-ize them in terms of electricals etc).
    beacon_dave over 2 years ago in reply to shabaz
    They appear to have discontinued the micro lathes from their line up. Disappointed
    I might have to consider upsizing to a mini lathe instead. Slight smile
    The mini appears to give a lot more flexibility over the micro, my main concern is the increase in weight.
    A lot of the mini / micro lathes appear to be rebadged versions of the Chinese Sieg models. However I believe that one of the first tasks tends to be to strip it down, replace various parts and then rebuild it in order to improve the accuracy/reliability.
    Hi Dave,
    Probably the mini is a still a nice size for home use. Also more future-proofed for needs I guess. For the milling machine I didn't go for the smallest, and am glad now, even though sometimes I wish I had an even larger one, I can make do with the one I have, whereas the micro would have been very restrictive.
    I have a custom DIY table, although they do sell tables for the machines, they are very basic and too small to leave a few tools nearby, I don't think it is worth buying them. We used chunky (maybe 100x100mm) fence posts from B&Q for table legs, and a thick wood base (and then there is the oil pan and then the machine), and the tabletop size is perhaps 700x700 (I've not checked) which is still compact, but allows me to leave the correct spanners and keys and oil and coolant bottles and a couple of large plastic component buckets with clamps and misc stuff,  all on the surface within easy reach.
    I think Arc Euro Trade do the stripping/rebuilding of anything that needs it to make it immediately ready to use, built-in to their prices. My milling machine was a Sieg one too, and needed no work (apart from a bit of cleaning of grease off surfaces and then replace with some oil).
    Hi Dave,
