Test & Tools
Test & Tools
Blog How Many Chucks Would A Woodchuck Chuck?
  • Author Author: dougw
  • Date Created: 2 Jan 2024 3:55 AM Date Created
  • Views 2092 views
  • Likes 12 likes
  • Comments 10 comments
  • Mini chucks
dougw
dougw
2 Jan 2024
If a woodchuck could chuck chucks, how many chucks would a woodchuck chuck?
The curious case of mini chucks galore....
A little light tool blog - part of my new year's reorg activities ...
All my mini chucks are now in a designated container.
Do you have a favorite mini chuck and what do you use it for?
Now what about utility knives and glue guns?
  • kmikemoo
    kmikemoo over 2 years ago
    dougw Great question.
    My favorite chuck is similar to the third one you showed.  I like using it for starter holes.  Power off, but manual on/in.  I can ruin stuff really fast with a powered tool.
    My "go to" knife is the slightly larger exacto knife with a metal handle (maybe a cm in diameter).  After that, I go for my pocket knife.
    I only have the standard small crafting glue gun, but I have a stack of index cards that I use as disposable place mats.  I also have a small bench with a slot in that holds the glue gun upside-down for when I'm letting it cool or not using it.  The index cards and the inverted stand... worth having.
    Finally, you have a few taps.  My tap set is from Harbor Freight.  It's fine for plastic.  It rarely survives metal.  My kit is slowly getting upgraded - one broken tap at a time.  I also managed to break the tap handle.  Again, slow upgrades.  I have looked seriously at mini lathes and milling machines, but fine work is not in my repertoire right now.
  • kmikemoo
