Test & Tools
Test & Tools
Blog mini project: PICO-PI programmable Lab Switch - 3: DIGI:OUTP command
  • Date Created: 18 Oct 2022 8:05 PM Date Created
  • Views 2135 views
  • Comments 8 comments
  • raspberry
  • pico_freertos_smp
  • pico_freertos_scpi_switch
  • pico
  • freertos
  • scpi
18 Oct 2022
In this series, I design a programmable lab switch based on RP2040, that can turn a set of signals or supplies on or off. Over USB. SCPI compatible.
In this post: add the SCPI command to switch an output (the LED in this demo): DIGItal:OUTPut# TRUE|FALSE.
Implement the SCPI command
In this post, we'll finally have a working design. Because all of the preparation work is done in the previous posts (set up FreeRTOS, UART, SCPI parser), the last step is very simple.
This is the command we'll support:
Where:
  • DIGItal:OUTPut (or DIGI:OUTP) is the command
  • # is the output you want to control.
    In this version there's one output with index 0: the on-board LED. See the Homework section later
  • TRUE|FALSE is the value. valid options are either 1|0 or ON|OFF
example:
DIGI:OUTP0 1
The command register:
   /* custom commands for the switch */
    {.pattern = "DIGItal:OUTPut#", .callback = SCPI_DigitalOutput,},
Array (size 1 Slight smile) of pins that can be controlled. The values are Pico GPIO pin numbers (the led is pin 25, but I use the constant that the Pico SDK defined):
#include "hardware/gpio.h"
// supported pins
uint pins[] = {PICO_DEFAULT_LED_PIN};
The handler of the DIGI:OUTP command:
static scpi_result_t SCPI_DigitalOutput(scpi_t * context) {
  scpi_bool_t param1;
  int32_t numbers[1];
  // retrieve the output index
  SCPI_CommandNumbers(context, numbers, 1, 0);
  if (! ((numbers[0] > -1) && (numbers[0] < sizeof(pins)/sizeof(pins[0])))) {
    SCPI_ErrorPush(context, SCPI_ERROR_INVALID_SUFFIX);
    return SCPI_RES_ERR;
  /* read first parameter if present */
  if (!SCPI_ParamBool(context, &param1, TRUE)) {
  gpio_put(pins[numbers[0]], param1 ? 1 : 0);
  return SCPI_RES_OK;
This one has three sections:
  • parse parameter 1: the index, 0 based. With validation  if it's in the array range
    note: in SCPI lingo this is actually a command number, not a parameter. This is the way to indicate what channel to operate on.
  • parse parameter 2: the state, ON or OFF
  • Set the GPIO pin that sits on that index to the state, using the Pico GPIO API
That is it. The parser lib makes it really easy to register and implement SCPI commands.
You can test this by sending the command DIGI:OUTP0 1 or DIGI:OUTP0 0 to the USB port. The led will turn on or off.
If you typed an error, you can always find that back: SYST:ERR:COUN? shows how many errors are stacked. SYST:ERR? pops the last error of the error stack.
Homework
These are easy-to-do improvements, that you can do yourself:
  • very easy: extend the array of pins. Currently it's an array of 1 element (the LED), but you can define many. All GPIOs if you want.
    The input validation will automatically adapt to the array size and only stack an error if you pass an index out of array range in the command
    Don't forget to initialise these pins as outputs in the main() function
  • very easy: write code that initialises the pins automatically: loop over all array items and set them as outputs.
  • still doable: write a command that returns the state of an output
    hint: {.pattern = "DIGItal:OUTPut#?", .callback = SCPI_DigitalOutputQ,},
project sources (VSCode compatible):
freertos_scpi_switch_20221019.zip
binary (uf2, you can use this for drag-and-drop programming). There's one if you are using UART (pins 0 for TX, 1 for RX - the usual setup when a picoprobe is in use) and a version that uses the Pico's USB.
scpi_switch_uart_and_usb_uf2.zip
Show all blog posts
    Jan Cumps over 3 years ago
    heads-up: the communication is via pin 1 and 2, not via the USB. This hadn't occurred to me, because I'm using a debug probe that connects to these. Shabaz noticed it.
    image source: https://www.elektronik-kompendium.de/sites/raspberry-pi/2611051.htm
    I'll check tomorrow how I can route the traffic to the ASB port, while still be able to use the picoprobe to program, and the interrupt mechanism ...
