Test & Tools
Test & Tools
Blog Minimum Specs for a OSCILLOSCOPE
  • Author Author: iggywarhol
  • Date Created: 31 Aug 2018 9:49 PM Date Created
  • Views 2136 views
  • Comments 8 comments
iggywarhol
iggywarhol
31 Aug 2018
i want to look at retro games as well as raspberry pi singles. I have no clue what frequency to buy.
    dougw over 7 years ago in reply to iggywarhol +4
    There are lots of scopes under $500 that have higher bandwidth, but for me personally in that price range I would be happy with a 2 channel 100 MHz scope and as much memory as possible. A good question…
  • iggywarhol
    iggywarhol over 7 years ago +2
    I am a senior software engineer I have done assembly on IBM 370 to writing stored procedures for large database. I want to to go back and learn the hardware of how cpu's, ram and etc work. I bought a FPGA…
    jw0752 over 7 years ago in reply to iggywarhol +2
    Hi Scott, Thanks for the back ground information. This will make it easier for the guys to give you a useful answer. John
  • iggywarhol
    I am a senior software engineer I have done assembly on IBM 370 to writing stored procedures for large database. I want to to go back and learn the hardware of how cpu's, ram and etc work. I bought a FPGA developer board and been having a blast with it. But I wan to look at the singles and such. I just not sure if a 100mhz scope with at least 2 channels is enough.  I have a budge of around $500. i can solder but not a big fan of it.
    I want to add I need to look at composite video signles too from C64 - Atri - ti 99/4a.s
  • michaelkellett
    michaelkellett over 7 years ago in reply to iggywarhol
    A mixed signal scope with 4 analogue and 16 digital channels would be ideal, that way you get the ability to look at a much larger set of digital signals.
    You need at least 100Mhz bandwidth, more would better - I couldn't find anything new in your price range except from Hantek and Owon. (online reviews are not encouraging image)
    Rigol have a low cost MSO1104Z that would do but it's quite a long way out of your price range (check the local price if you can stretch) It now comes with the full set of decoding options included.
    You could consider second hand but be careful that you get all the leads and probes.
    If you must stay in budget go for  a 4 channel scope and maybe trade up to an MSO later or buy a separate logic analyzer.
    MK
  • michaelkellett
    MK
    Jan Cumps over 7 years ago in reply to michaelkellett
    Alternative, elaborating on michaelkellett 's last sentence
    High frequency requirements are mostly because you need them for the digital protocols (I2C, SPI, ...). The non-communication part can often be analysed with more moderate frequencies.
    If you get a USB logic analyser (these can be purchased for less than 100 $/£/€) to deal with analysing the protocols, there's less  requirement to have a high frequency scope.
