Test & Tools
Test & Tools
Blog Reducing Common-Mode Noise with Ferrites
  • Author Author: shabaz
  • Date Created: 28 May 2026 3:49 PM Date Created
  • Views 496 views
  • Likes 10 likes
  • CM noise
  • choke
  • ferrite
  • measurement
  • Common-Mode
  • noise
shabaz
shabaz
28 May 2026
Making low-noise measurements can be hard! Sometimes, if the device-under-test is small, I try to place it inside a shielded enclosure. There are some (+) Ideas on Building a Shielded Test Enclosure - element14 Community here.
There was a recent discussion concerning noise with an amplifier module setup which involved USB power and an audio signal from a PC. I tried to replicate it, and one of the experiments involved using a common-mode choke component, wired into the supply connections.
When working with cables, it’s possible to use ferrite cores as a common-mode choke too; that's the bulky thing often seen on USB cables for instance.
I recently tried to measure the noise on a power supply, and shot a quick video (with handheld mobile phone otherwise I would never have got around to a proper recording; sorry for the poor quality) showing my attempts to reduce noise pick-up from the environment.
While I managed to get the noise low enough that I could proceed with my end measurements, I’m not going to suggest this is best practise (I could have put more thought into using an actual 'scope probe, or considered a 50-ohm termination measurement perhaps with a capacitor to remove the DC component. Plus, the cable I used doesn’t have a controlled impedance for instance, and the measurement may only be usable for a few tens of MHz), but, I thought it may be interesting to share the video anyway, since it shows some of the considerations I had to make (such as powering off lights/equipment nearby to reduce pickup).
If you have any tips/tricks, or encountered interesting noise related issues, please share them!
    DAB 5 months ago
    Very interesting.
    I learned how to use ferrite cores back in the 1980's when we had to send our box for EMI testing.
    Initially, we failed miserably, but then we hired their engineers to consult and they showed us how to use ferrite cores to clean up everything.
    A little rework and we had a box that passed.
    We installed it in the helicopters and it worked fine.
