Test & Tools
Test & Tools
Blog Retro: Philips 1542 DC power supply
  • Date Created: 11 Jun 2020 7:31 PM Date Created
  • Views 5546 views
  • Likes 10 likes
  • Comments 16 comments
  • restorerepairch
11 Jun 2020
A little bit of nostalgia: my Philips power supply.
3 channels. Isolated. Constant voltage and constant current.
And perfectly silent - no spinning fan.
Made in Belgium!
click to enlarge
Over here, Philips was the go-to brand for lab instruments.
When I studied electronics, every instrument - except some Kyoritsu meters - was a Philips.
In my own lab, this supply and a Philips oscilloscope were the pièces de résistance.
I've sold the scope. I still use the power supply a lot.
Specifications:
3 isolated channels:
  • 2 * 0 - 32 V, 1.4 A
  • 1 * 5 V, 3 A
Voltage and/or Current regulation.
Silent!
Focus is more on reliability than smooth output.
Specs and schematic below are for the 1542/00 (20 V 20 V 7 V) while mine is a 1542/60 (32 V 32 V 5 V).
Appreciate the discrete input stage <3
Does It Still Work?
Yes. The 3 channels still work perfectly.
The only defect is that the V/A switch of one of the channels doesn't work anymore. It can't show the current on the meter.
It's a known thing with these supplies. Here's someone that shows how to fix that.
That link also shows that there were many configurations for the 3 channels, all sold as the same model number.
When I don't need a programmable supply, this one is ideal.
It's a good supply. Not having a fan next to your ear is a luxury.
And it has been good enough for many labs for many years.
    Jan Cumps over 6 years ago +5
    I'm opening it up to fix the volt / amp switches. I'm filming the exercise, and have taken some pictures. Video is for later, when the project is finished.
    Jan Cumps over 6 years ago in reply to geralds +4
    Yes:
  • geralds
    geralds over 6 years ago +3
    It is a typical µA723 power supply. "... hmmm ..." sweet "! - the scent of pertinax.
  • Wintitech
    Wintitech over 1 year ago
    Hi Jan,
    I have actually repaired the same power supply - the main capacitors were dried and made interal short circuit.
    One open issue I have, but not sure if its immanent in the powersupply: When you turn the Current limiting knob (0-3A) of the 5V output down to zero, the voltage will be cut off.
    But when you turn the powersupply off and then on again, there will be a 5V output given for about a half of a second, before it returns to zero again.
    Do you have the same effect on your Powersupply?
    Kind regards
    Andy
  • Wintitech
    Hi Jan,
    Kind regards
    Andy
    Jan Cumps over 1 year ago in reply to Wintitech
    I can't test it anymore. I've given it away to a makerspace a few years ago.
    I don't recall if I ever had this situation. Most likely yes, because it's the same design.
  • Wintitech
    Wintitech over 1 year ago in reply to Jan Cumps
    Hi Jan
    Thanks for your reply. All the best and
    Kind regards
    Andy
