Test & Tools
Test & Tools
Blog Siglent SPD1305X
  • Author Author: kk99
  • Date Created: 9 Jun 2026 5:49 PM Date Created
  • Views 665 views
  • power supplies
Siglent SPD1305X
kk99
kk99
9 Jun 2026
Today arrived my power supply, that bought few days ago. It was a good occasion to buy almost not used device in half of current price. The device is in the condition as described by the previous owner. It still has a product seal. After disassembling the cover, there was a bit of dust, but everything looked fine. I just cleaned it with compressed air.
I have performed quick tests, and it looks like everything works properly. The regulated fan is very silent, especially if I compare it to the SDS824X HD scope, which is a bit noisy. Below a measurement from OFF-ON and OFF-ON transitions with a connected load 51.1 Ohm resistor. The power supply was set to 8V and 40mA.
    DAB 4 months ago
    Do you have a specific use for the supply or just needed one for your bench?
    DAB 4 months ago
  • kk99
    kk99 4 months ago in reply to DAB
    I lacked a power supply to power more demanding receivers. For quick tests of op-amps circuits, I used power supply from Analog Discovery 3, but sometimes something serious was required. I have limited space, so I searched for something compact. I thought about Matsusada from RK-80 series, but it was hard to find. I have tested the Alientek DP100, but it was also limited by the input voltage and user interface was not quite intuitive. So, finally ended with this, which has a good compromise.
