Test & Tools
Test & Tools
Blog Silicon Solder Mat
  • Date Created: 6 Feb 2021 4:39 PM Date Created
  • Views 6243 views
  • Likes 14 likes
  • Comments 47 comments
Silicon Solder Mat
6 Feb 2021
I purchased a silicon solder mat today, when I was in the electronics shop to pick up my order.
I use an antistatic mat as a generic work area, and prefer to keep that tidy. That mat can take an accidental touch of a hot iron, but it's not intended for that.
The silicon solder mat (from Velleman - Buy Belgian!) is heat resistant, up to 500° C.
Flexible and can be cleaned in a kitchen sink. It returns back to its original form.
Total size 45 x 30 cm. Work area without covering anything is approx. 40 * 28. It costed 20 €.
One of the biggest advantages for me is that it's easy to pick up and stow away. My lab is used as office, diner table and lab bench, depending on the time of day.
I prefer to have a reasonable clean desk. I remove instruments and projects when I use the desk as home office. And vice versa.
I'll report back in a while how the thing behaves in the real world. If I'm happy with the purchase or regret it.
  • ntewinkel
    ntewinkel over 5 years ago in reply to Jan Cumps +9
    Jan Cumps wrote: Mine has Velleman printed on it and that is better ! These would actually make great element14 swag. It's already the right colour too... just need some orange printing added. Velleman…
  • 14rhb
    14rhb over 5 years ago +7
    Hi Jan Cumps , I've the same mat, as you already ellude to, they are great for keeping the solder 'mess' in one place and I don't think you'll regret your purchase I bought my one to save me the embarassment…
  • ralphjy
    ralphjy over 5 years ago +7
    I use a smaller one - 35 x 25 cm, somewhat thinner (3.5mm) and without magnets. It works really well and is the perfect size for the type of soldering that I do. It was $8 from Amazon.
    shabaz over 5 years ago in reply to Andrew J
    Good point.. I didn't think about it at the time, but I suppose it's going to be quite similar to leaving burn marks when branding an animal : (
    Also it probably does get smelly when burned! : (
    Jan Cumps over 5 years ago in reply to Andrew J
    Leather holds up but it burns. Your iron will leave marks.
  • Andrew J
    Andrew J over 5 years ago in reply to shabaz
    Not sure how well leather would stand up to soldering and hot air temperatures.  Leather is such a lovely, tactile surface I’d hate to damage it!
    Jan Cumps over 5 years ago in reply to ntewinkel
    Were the lids too annoying?
    Yes, every time I put the mat away they were flapping around in the breeze. I have no need for closed compartiments.
    I still have the flaps so if I change my mind I can put them back on.
    • Vote Up +5 Vote Down
  • ntewinkel
    Jan Cumps  wrote:
    Status update... <picture>
    The parts boxes are now parts compartments?
