Test & Tools
Test & Tools
Blog Soldering Iron Thermometer QUICK 191AD Review
  • Author Author: shabaz
  • Date Created: 19 Sep 2021 8:52 PM Date Created
  • Views 5087 views
  • Likes 10 likes
  • 191ad
  • quick
  • soldering_tools
shabaz
shabaz
19 Sep 2021
I recently bought a QUICK 191AD soldering iron thermometer, here's a 3-minute review : )
This instrument costs about £100 in the UK (a couple of resellers in the UK stock it). It comes with a pack of ten sensors, there is a spring peg to hold it taut. It's a type-K thermocouple basically.
I cannot say it is the most useful tool in the world, I'm unlikely to use it often just to check soldering iron tip temperature. I may get a bit more use out of the tool simply because it has a connector for a normal external thermocouple probe too. One is supplied with the tool.
Functionality is pretty basic; all it does is display the temperature in degrees C (1 degree C granularity) between -13 and 973 degrees C, there is a Fahrenheit button, plus a useful Max-Hold capability, and the power-off time is configurable. The internals show that the design is quite ancient:
There's lots of spray coating on the board, and I couldn't read off any IC part numbers, unfortunately.
The instrument comes with calibration, and it is accurate (I tested with a thermocouple simulator/calibrator tool) across the entire range. My soldering iron was measured by the instrument to within 5 degrees C of the set temperature.
To summarize, the instrument is quite basic, but since it comes with calibration, is accurate, and can be used with an external thermocouple, I think that goes some way toward making the tool more useful.
Thanks for reading!
  • baldengineer
    baldengineer over 5 years ago +1
    Thanks for posting the video. Today I learned I have been using my meter wrong. I had been putting pressure on the sensor. For example, basically resting the iron tip on it. I was, at least, already using…
  • baldengineer
    I was, at least, already using a solder drop to make thermal contact. image
  • baldengineer
