Test & Tools
Test & Tools
Blog Soldering Irons
  • Author Author: fluxcap
  • Date Created: 4 May 2018 9:10 PM Date Created
  • Views 3682 views
  • Comments 20 comments
  • soldering station
  • soldering iron
  • soldering
Soldering Irons
fluxcap
fluxcap
4 May 2018
I'm looking to step up my soldering game. I've seen the relatively new intergrated heating element into the soldering iron tip, like the JBC stations. Does anyone know a budget version that uses the same tech?
    jw0752 over 8 years ago +4
    Hi Jade, Here is a great soldering iron that was given to me by a good friend. I have been using it every day for about a year and it is still on the first tip. You can set the temperature anywhere you…
    shabaz over 8 years ago +3
    Hi Jade, I've not used it myself, but we specified Metcal PS-900 for a few sites, no complaints so far. It is fairly low cost. It uses Metcal's own system, which is like a competitive technology to other…
  • fluxcap
    fluxcap over 8 years ago in reply to genebren +3
    I looked at it and it seems to be a good choice only that your counting on the smartheat thing to adjust for the temp. I'd rather be able to control it. Also if you know of any really good old tech soldering…
    genebren over 8 years ago
    Hi Jade,
    I would agree with shabaz, I own a PS-900 which I really like.  I have used Weller prior to that but I had a lot of trouble getting the temperature just right and as a result I would burn through tips (lead-free) rather quickly.  Having used the PS-900 for more that a year, I would say that it was well the the price.
    Good luck!
    Gene
  • fluxcap
    I looked at it and it seems to be a good choice only that your counting on the smartheat thing to adjust for the temp. I'd rather be able to control it. Also if you know of any really good old tech soldering stations, anything would be better than the weller WLC100 I have now. It doesnt really give a good idea of the temp because your temp control is just a pot with the numbers 1-5. Also thanks for the input!
  • fluxcap
    genebren over 8 years ago in reply to fluxcap
    Yeah, my Weller is WESD51, with real temperature control (actual degrees).  There are a lot of accessories for these irons and it was a workhorse.
    Gene
    Jade,
    I understand your concern about Metcal irons and a lack of the adjustability, but I have never had an issue.  Sometimes, when you are soldering larger components (or components attached to heavy traces, i.e. power planes), the smaller tips do not provide enough heat to flow the solder, but switching to a larger tip is easy and it gets the job done.
    Gene
    shabaz over 8 years ago in reply to genebren
    Even with JBC models one would want to switch tips when going from (say) small surface-mount to soldering large connectors or power planes as you say.
    I remember seeing the earlier Metcal models and being astonished at their performance, which was the reason we went with the PS-900. From what you say, it sounds like it was a good decision.
  • fluxcap
    I found a WESD51 very lightly used one on ebay for 133 including shipping would you say thats a good deal?
    Jade,
    I see a new unit (WESD51D) listed at $212 with free shipping. I bought my Metcal off of ebay for $153.00 (new or reconditioned) after a fair amount of following various auctions (about 1 1/2 years ago). So, $133.00 might be an OK deal, but you could probably do better.
    Gene
