Test & Tools
Test & Tools
Blog Soldering Irons
  • Author Author: fluxcap
  • Date Created: 4 May 2018 9:10 PM Date Created
  • Views 3607 views
  • Comments 20 comments
  • soldering station
  • soldering iron
  • soldering
Soldering Irons
fluxcap
fluxcap
4 May 2018
I'm looking to step up my soldering game. I've seen the relatively new intergrated heating element into the soldering iron tip, like the JBC stations. Does anyone know a budget version that uses the same tech?
    jw0752 over 8 years ago +4
    Hi Jade, Here is a great soldering iron that was given to me by a good friend. I have been using it every day for about a year and it is still on the first tip. You can set the temperature anywhere you…
    shabaz over 8 years ago +3
    Hi Jade, I've not used it myself, but we specified Metcal PS-900 for a few sites, no complaints so far. It is fairly low cost. It uses Metcal's own system, which is like a competitive technology to other…
  • fluxcap
    fluxcap over 8 years ago in reply to genebren +3
    I looked at it and it seems to be a good choice only that your counting on the smartheat thing to adjust for the temp. I'd rather be able to control it. Also if you know of any really good old tech soldering…
  • fluxcap
    I looked at it and it seems to be a good choice only that your counting on the smartheat thing to adjust for the temp. I'd rather be able to control it. Also if you know of any really good old tech soldering stations, anything would be better than the weller WLC100 I have now. It doesnt really give a good idea of the temp because your temp control is just a pot with the numbers 1-5. Also thanks for the input!
  • fluxcap
    fluxcap over 8 years ago in reply to andywest
    Your right that thing just looks like a really smart toaster!
  • andywest
    andywest over 8 years ago
    I've heard that the Hakko FX-951 is comparable to some of the JBC stations but at a lower price. It's been around for a while and it's a bit ugly in my opinion, but it's made for soldering and not staring at, so meh.
    genebren over 8 years ago
    Hi Jade,
    I would agree with shabaz, I own a PS-900 which I really like.  I have used Weller prior to that but I had a lot of trouble getting the temperature just right and as a result I would burn through tips (lead-free) rather quickly.  Having used the PS-900 for more that a year, I would say that it was well the the price.
    Good luck!
    Gene
    Hi Jade,
    It is fairly low cost. It uses Metcal's own system, which is like a competitive technology to other vendor technologies.
    I'm sure there are other good solder stations out there too, at even lower cost.
