Test & Tools
Test & Tools
Blog Soldering Wishlist gift! Duratool D00374 fume extractor
  • Author Author: strb
  • Date Created: 10 May 2023 7:37 PM Date Created
  • Views 1479 views
  • Likes 13 likes
  • Comments 6 comments
  • duratool
  • Solder Fume Extractor
strb
strb
10 May 2023
A huge thank you to the E14 community that chose me as one of the lucky winners for the Wishlist - What do you need for Soldering? giveaway. This is my first prize/gift from the E14 community and that makes it special for me!
A rather big (and beat up) box was delivered to my door.
Inside this box, another box came out. Extra space was filled with paper.
Still, some "love marks" from shipping are visible on the inside box, but the nice packaging successfully defended the precious product inside. Other than the main piece, from the box came out a small piece of paper with specs and warnings and a bag with spare filters. I did not expect that and it's a nice addition!
And here it is my new shiny fume extractor, side to side with my previous DIY attempt using an old 12V PC fan. Compared to my former setup, this new piece of equipment looks quite nice and professional!
I think that everybody that does solder needs some sort of fume extraction, even a simple fan as I used before is perfect for hobby work (I don't like flux smell at all Slight smile).
For those who could be interested I tried to make a short video showing noise level and working distance of this product. It's not a good video by any means, but I hope that at least these two points are clearly shown.
Let's go solder!
  • strb
    strb over 3 years ago in reply to srutledge
    That's sure! Thank you! Slight smile
  • srutledge
    srutledge over 3 years ago
    Woohoo! Glad it made it to you in one piece, hope it gets a ton of use :D
  • strb
    strb over 3 years ago in reply to Andrew J
    That probably would help.
    Also, in my test the fume extractor was not tilted in any way. On the side there are a couple of thumb screw that allow it to tilt forward or backward. I bet that pointing it slightly down toward the pcb could help too.
  • Andrew J
    Andrew J over 3 years ago
    A good demonstration. I find I get my head quite close to the work, maybe 8 to 10cm, so I can see the SMD components and pads properly.  The fumes were able to rise somewhat before being sucked away - I wonder if some sort of hood attachment with nozzle at the other end, positioned close to the work, would help.
  • strb
    strb over 3 years ago in reply to misaz
    Thank you!
