Test & Tools
Test & Tools
Blog The Modular Bench Power Supply ++ - Simple Display Setup
  • Author Author: Robert Peter Oakes
  • Date Created: 13 Nov 2014 5:33 AM Date Created
  • Views 2391 views
  • Comments 7 comments
  • displays
  • tutorial
  • bench
  • digital
  • projects
  • modular
  • display
  • supply
  • power
Robert Peter Oakes
Robert Peter Oakes
13 Nov 2014
This is the start of the next blog in my series for the LAB bench power supply, in this video I will explore an option of using dedicated Digital displays to show the current and Voltage and how having a display with differential inputs can help eliminate errors
Back to main PSU blog http://www.element14.com/community/groups/test-and-measurement/blog/2014/09/15/the-modular-bench-power-system-the-essential-diy-build-for-every-ee-student-and-old-timer-alike
I will be adding the schematics by the weekend, in the meantime, enjoy the video
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to DAB +1
    there not actually power meters, the ones I got from Newark/Farnell are simply 5V powered, 3.5 digit, +-200mV FSD. (I know an analogue term) but I used a select low value resistor to convert the current…
    Robert Peter Oakes over 11 years ago in reply to heffa +1
    I got a bit behind in the XMAS holiday challenges to am playing catchup, they will be there soon
    DAB over 12 years ago
    Great video Peter,
    I was not aware that those little power meters were available.
    I will have to pick some of them up.
    Great video Peter,
    but I used a select low value resistor to convert the current into a 0-200mV range representing 0-2A, the one used for voltage is simply connected to the low side of a 100:1 resistor network divider, simple as that.
    I will provide schematics for it.
    Also as a Heads up. Vishay Precision Group (VPG) , remember the webinar that recently showed from Powertron, well this is them, they have sent me a selection of sample 4 terminal (Kelvin connection ) resistors of low values (1ohm down to 0.01Ohm) and heavy power versions too, with something like 2ppm temp co-efficient which is awesome and a couple even 0.1% tolerance too.
    There also sending me some HIGH precision resistor divider network devices in something like a TO92  and TO220 packages, the divider networks are something like 0.01% accurate and perfect for instrumentation OPAMP feedback loops or for scaling to a display input, perfect for instrumentation
    I will be dedicating a whole episode on them, well the principle of kelvin connections,purpose built power sense resistors, the choice of cabling in a build and the benefits of precision components
