Test & Tools
Test & Tools
Blog The Modular Bench Power Supply ++, More on Displays and using an Arduino to measure Volts and Amps
  • Author Author: Robert Peter Oakes
  • Date Created: 17 Feb 2015 4:55 AM Date Created
  • Views 1321 views
  • displays
  • lcd
  • low_cost
  • adc
  • modular_bench_power_supply
Robert Peter Oakes
Robert Peter Oakes
17 Feb 2015
As you can tell from all the videos, im playing catchup, sorry about that
In this video we look at using an Arduino UNO to measure the volts and Amps for a power supply and also have a look at more display options from overseas
As a side note, I was pleasantly surprised at the results of the low cost Volt and Ammeter as well as the Arduino ADC
    jw0752 over 11 years ago
    Hi Peter, I enjoyed your presentation on the meters. I have used the cheaper LED panel meters in several projects and found them to be quite accurate. I will point out that properly mounting them through a panel necessitates removing the guts from the bezel and inserting the bezel through the panel and then reinstalling the guts. If you do not do it in this sequence the circuit board of the meter doesn't allow the bezel clips to compress. Thanks as always for your tutorials.
