Test & Tools
Test & Tools
Blog Turn a standard oscilloscope into a solder-in one
  • Date Created: 11 Feb 2022 4:33 PM Date Created
  • Views 6259 views
  • Likes 12 likes
  • Comments 9 comments
  • lab_tips
  • probes
  • oscilloscope
  • circuitprototypingch
  • circuitprototypetechniques
11 Feb 2022
This is a reaction post on baldengineer's excellent Workbench Wednesdays 50: DIY Solder-In Oscilloscope Probes.
There have been several posts here on the community to related to the topic, like this one from shabaz: Building Solderable In-Circuit Oscilloscope Probes (the design that inspired James), Andrew J's solution with ferrules and this one from me: DIY $10 Solder-in Oscilloscope Probe.
I was thinking about a simpler one that uses an off-the-shelf probe, keeps impedance, compensation and x1/x10 intact, and does not destroy the probe. Battle of the probe techniques ...
I came up with this design:
Making it took 7 minutes. Filming a lot more  :).
Also kudo's to W2AEW because virtually every technique comes from one of his videos.
Result:
    Jan Cumps over 4 years ago in reply to shabaz +1
    I've tagged this for the Circuit Prototype Techniques month. I've just seen that there are good entries for it already .
    Scope capture of the Arduino USB clock:
    I used AC coupling because my scope's trigger doesn't deal well with MHz range signals with DC offset.
    Standard acquisition settings, and using the hardware frequency counter.
    This image will not be better than using the pig-tail probing technique. But it offers hands-free operation.
    It's definitely better compared to using the crocodile probe ground lead.
