Test & Tools
Test & Tools
Forum FCC / CE Test house - recommendations for a start up
  • Subscribers 385 subscribers
  • Views 969 views
  • fcc
v-juice
v-juice over 7 years ago
Do you have a recommendation for an FCC / CE Test house with offers reasonable costs?
Many thanks for your feedback in advanvce,
Tilman
    michaelkellett over 7 years ago
    Well, first you might consider telling us where you are - it might narrow the field down a bit image
    Then you could tell us what kind of device you want to have tested , and maybe indicate the kind of price you hope to pay.
  • v-juice
    v-juice over 7 years ago in reply to michaelkellett
    Hello MK,
    many thanks for your quick answer!
    We are located in Germany, Munich.
    It is about an inductive charger.
    We are a start up in an early phase, so money is tight. But we are aware, that FCC is required.
    Best regards,
    Tilman
    michaelkellett over 7 years ago in reply to v-juice
    Sorry - I'm in the UK so can't help much.
    Generally I've found that you get much better service and lower cost from small local labs rather than the multi-national chains.
    It may be different in Germany.
    If you can't get a good recommendation just visit the test lab nearest you and see if you like them. (You can get quotes from others to compare - expect to have to provide quite  a lot of information to get a quote.)
    dougw over 7 years ago
    Around here these test facilities charge about $2000 per day and it could take a few days.
    One thing you should do to minimize cost is try hard to make sure your device passes on the first visit to a test facility.
    Do your homework on how to design your system to pass and try to test your system yourself before going for certification at a 3rd party facility.
