Test & Tools
Test & Tools
Forum Protection on Sefram BK 8500
  • Subscribers 384 subscribers
  • Views 298 views
  • bk
  • on
  • 8500
  • sefram
  • portection
dsohal
dsohal over 17 years ago
The reason for my enquiry was that your manual does not say  that the 8500 input is isolated in the OFF state. If this is not the case, it  would still be possible to damage the 8500 by exceeding the rated  voltage.
I wanted to be sure that the over-volatge protection is not  intended to protect external circuitry from overload by turning OFF the 8500,  and that instead, it will protect the 8500, even if its rated input voltage is  exceeded.
When  the input is off, the measurement range is still the rating voltage of the  machine, if the input exceed the rating voltage, then the Over Voltage  Protection will work.
If  the input voltage exceed too much, it may damage the electronic  load.
