Test & Tools
Test & Tools
Forum Very hi-temp ICs and/or microchips for inside a running combustion engine
  • Replies 7 replies
  • Subscribers 387 subscribers
  • Views 1132 views
I am looking to build a small (very small) wireless transmitter using a thermistor that will operate inside of a running combustion engine in order to measure piston or connecting rod temps.  I have done this by making a long and painful drilling continuously through the crankshaft and then mounting the telemetry in the open air mounted in the crank pulley.
However, sometimes I want a single reading off a piston in the middle of the engine, thus a small single channel device.  I have run chips successfully up to their 250 F limit (and a little beyond), but then this requires special oil cooling and creates bias in the measurement usually.  Are their any chips that will function even briefly at 400 F in a heavy, hot, dirty oil bath... and while whirrling around or oscillating rapidly?
I am familiar with PIC chips... but am no computer scientist.
Thanks, Matt
  • enrico.migchels
    enrico.migchels over 16 years ago
    Hi There,
    Microchip devices can run up to 423K, so that wil not cause problems, but a wireless in a metal compartment? Sound like a perfect Faraday cage to me... I think you have to start drilling again. :-)
    Best regards, Enrico Migchels
    e14 Contributor over 16 years ago in reply to enrico.migchels
    Right, 423K = 150C = ~ 300 F... have already done this... looking for another 100 deg F.
    Farad Box??  I have already made this work -  the oil pan is plastic and no antenna is required, it broadcasts right through.
    ...k, Matt
  • enrico.migchels
    enrico.migchels over 16 years ago in reply to e14 Contributor
    Ok Matt,
    Sorry I could not add anything worthwhile for your problem. I will give it another thought...
  • enrico.migchels
    Hi Matt,
    I would advise you to contact Honeywell. They have experience in high temperature sensors. They have designed special components for the temperature range you are interested in. With standard 150C electronics the expected life can be anything between seconds and days and therefore never the way to proceed.
    Thank you for your replies.  Matt
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Hello, you might also have a look at the company CISSOID ( www.cissoid.com )
  • MicrochipRTCfr
    MicrochipRTCfr over 16 years ago
    There is a dedicated design center for the analog, memory & PIC Microchip products which can operate at 150C : http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2844&param=en544687
    regards
