Test & Tools
Test & Tools
Forum Need Help on Test and Measurement? Ask me a Question!
  • Replies 11 replies
  • Subscribers 386 subscribers
  • Views 2231 views
  • test
  • cynergy3
  • measurement
  • john_mason
  • engineering
  • test_and_measurement
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Test & Measurement in the element14 Community Test & Measurement group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
John Mason
John Mason is currently VP Sales & Marketing for Cynergy3's US operations, based in Cypress, CA.  Originally from England, John graduated from the University of Plymouth in 1993, receiving a Bachelors Degree in Communication Engineering. He worked for many years in the Engineering department of Cynergy3's UK factory in Wimborne, Dorset, designing Radio Frequency and High Voltage Reed Relays.   During his extensive travels world-wide, in Engineering and Sales/ Marketing roles, John has gained much experience in assisting Design Engineers in selecting the right Cynergy3 product.  He welcome's your technical enquiries and is backed up by an expert team of Engineers in the UK factory.
    hi John,
    I have to implement the 10MHz reference signal project for our measurement devices.
    I  would like to know if Tektronix does have GPS disciplined Rubidium  oscillator devices  + antenna + surge protection + redundancy option
    thank you ,
    Radu
    so plz sir can u tell me projects ? plz sir can u telll me quickly?
  • shobhitkukreti
    shobhitkukreti over 15 years ago in reply to e14 Contributor
    gurucool, it depends on what is the level of your understanding of electronics. Would you like to work on Signal processing ?
    Greetings Mr Mason!
    I hope I'm directing my question to the right category, but I'm pretty sure I did...
    Anyway, currently I'm working on my bachelor thesis. Summing it up, I'm trying to trace back fluctuations of a plasma jet via measures based on the variations of the magnetic field, caused by the plamsa arc inside. And right there comes my question: At farnell's online shop I found a hall effect sensor (http://de.farnell.com/honeywell-s-c/ss311pt/sensor-hall-effekt-bipolar-sot/dp/1784726). If the link does not work, it's called 'HONEYWELL S&C - SS311PTSS311PT - SENSOR, HALL EFFEKT, BIPOLAR, SOT-23'. Problem is: Does it measure a particular component of the magnetic field our does it only meter the alteration of the magnetic field? Point is: I need a sensor, which shows me the changing of one component. Could you help me with that, or is it possible that you can tell me a similar sensor which agrees with my requirements (every other feature of the previously mentioned sensor would fit to my experiment). Thank you so much in advance! Kind regards
    PS: I'm hoping my English wasn't too bad, I'm writing from Munich, Germany
    Hi John,
    I'm not certain that you are the correct person to contact but we are an Australian glass and aluminium manufacturing company and use your steel rule (35-406) to test and calibrate our rulers, guides, machinery etc.  We were recently audited and the question was raised as to the calibration of our testing equipment.  I have looked on your website for some further information about it but have had no luck.  Are you able to give me any information about the 35-406 including any guarantee timeframes.  We do of course check and compare it against other products but have no actual calibration or guarantee standard to back it up.  Kind Regards, Caroline Dickson
    Hi i m Denise. I need help to find a way to program a graphic LCD (BTHQ128064AVO) by using dspic33f128GP804.
    Regards
    is there any difference between the HItect C and CCSC
    Please provide the above amount
    Can I conect Wifi module or USB modem to R pi for internet Acess? I am a newbee.Thanks
    How do You enter the online drawing contest
