Test & Tools
Test & Tools
Forum InfiniiVision X-Series Oscilloscope from Agilent DSO and MSO  MSOX3000 DSOX3000 MSOX2000
  • Subscribers 384 subscribers
  • Views 1210 views
  • infiniivision
  • x-series
  • http://wireless.agilent.com/flash/infiniivision/xseries/index.html
InfiniiVision X-Series from Agilent
2000X and 3000X series available in both DSO and MSO versions.
Watch the latest video from Agilent comparing the InfiniiVision X-Series  http://wireless.agilent.com/flash/infiniivision/xseries/index.html
image Agilent - 3000X Series Oscilloscope data_sheet_5990-6619EN.pdf
image Agilent - 2000X Series Oscilloscope 5990-6618EN.pdf
image Agilent - 3000X series User Manual 75019-97013.pdf
image Agilent - 2000x Series User manual - 75015-97011.pdf
image Agilent - 2000 & 3000 X-Series Oscilloscope Measurement Options - 5990-6676EN.pdf
3000-X Infinnivision Range3000-X Infinnivision Range
InfiniiVision 2000 X-Series
InfiniiVision 3000 X-Series
Analog channels
2 and 4 analog channels
Bandwidth (upgradable)
70, 100, 200 MHz
100, 200, 350, 500 MHz
Sample rate
1 GSa/s per channel
2 GSa/s half-channel interleaved mode
2 GSa/s per channel
4 GSa/s half-channel interleaved mode
Memory depth
100 kpts
2 Mpts standard, 4 Mpts optional
(Option DSOX3MEMUPDSOX3MEMUP)
Waveform update rate
50,000 waveforms per second
1,000,000 waveforms per second
Digital timing channels
8 on MSO models or with
DSOX2MSODSOX2MSO upgrade
16 on MSO models or with
DSOX3MSODSOX3MSO upgrade
WaveGen built-in 20 MHz
function generator
Yes (Option DSOX2WAVEGENDSOX2WAVEGEN)
Yes (Option DSOX3WAVEGENDSOX3WAVEGEN)
Search and navigate
No
Yes
Serial protocol analysis
No
Yes (multiple options)
Segmented memory
Yes (Option DSOX2SGMDSOX2SGM)
Yes (Option DSOX3SGMDSOX3SGM)
Mask limit testing
Yes (Option DSOX2MASKDSOX2MASK)
Yes (Option DSOX3MASKDSOX3MASK)
AutoProbe interface
No
Yes
imageAgilent - 2000 & 3000 X-Series Oscilloscope Measurement Options - 5990-6676EN.pdf
imageAgilent - 2000x Series User manual - 75015-97011.pdf
imageAgilent - 3000X series User Manual 75019-97013.pdf
imageAgilent - 2000X Series Oscilloscope 5990-6618EN.pdf
imageAgilent - 3000X Series Oscilloscope data_sheet_5990-6619EN.pdf
