Test & Tools
Test & Tools
Forum Home labs of electronics engineers?
  • Replies 80 replies
  • Subscribers 391 subscribers
  • Views 17068 views
  • precision
  • test
  • time-nut
  • lm399
  • hardware
  • homelab
  • tektronix
  • voltage
  • keithley
  • volt-nut
  • ltz1000
  • equipment
  • references
  • lab
tin_xdevs
tin_xdevs over 11 years ago
Or should I say more, caves? That's what volt-nutting can bring you into:
Home lab
Most of gear was saved from scrapping by repairs. Collected stuff over last 5 years or so. DMM collection quickly grew after getting into precision DC voltage obsessions, with voltage references and such.
Total list of gear as by today:
6 x Keithley 2001 DMM (2 still need some repairs)
1 x Keithley 2002
1 x Keithley 2000 (not shown here)
1 x Keithley 2400 SMU
1 x Keithley 2510 TEC SMU
HP 4263B (LCR Meter)
HP 33120A ARB 15MHz
Tektronix CSA7404 with pair of P7380 probes  TCA-1MEGTCA-1MEG some P6245's
Tektronix TLA714 with TLA7AA4 and set of probes (P6810, 2 x P6860, some mictor adapters, etc)
EDC MV106 DC Voltage standard (+-30ppm)
Few selfmade LM399 and Linear LTZ1000 stable references
ESI DB52 decade resistor
ERSA ICON1 soldering iron
Bunch of Vishay Precision Group 0.2ppm resistors for testing/calibration.
What drives you? Do you have homelab? Reveal your bunkers image
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +9
    Well I was brave enough to share my junk LAB way back so here is the new and improved version and through the door to the right is my workstation (A little messy) Yes thats a PI 2 on the desk with full…
    jw0752 over 11 years ago +8
    Hi Illya, Wow, What a beautiful concentration of precision. It looks like you have a variety of projects in the works too. I have recently up graded my shop area in the basement. It is always a work in…
  • spannerspencer
    spannerspencer over 11 years ago +8
    I'd like to see this at the Smithsonian (among a lot of other things, natch). They've recreated Ralph Baer's home workshop as an exhibition, and his original Brown Box console prototypes are there too…
  • Problemchild
    Problemchild over 11 years ago in reply to shabaz
    Why does Illya have soooo very many Multimeters? It's not fair he has more than me ...he's very scarey ..Shabaz make him go away image!!
    jw0752 over 11 years ago in reply to Problemchild
    Not only does he have them but he really knows how to make them stand up and do tricks. He is a master of the Keithley DMM.
  • Problemchild
    Problemchild over 11 years ago in reply to jw0752
    Yeah Keithley are good. Bagged myself a Keithley THD2015 recently..recommended it to Shabaz only to find he already got one image
    shabaz over 11 years ago in reply to Workshopshed
    Hi Andy,
    Lol. LEDs are in some ways the ultimate test tool all round : ) So compact, and so many uses in troubleshooting : ) since they don't load some circuits much at all (less than an analog multimeter!).
    Other easy-to-obtain test tools are a radio, and an audio amplifier, and any microcontroller board for general circuit stimulation and capturing data. I like jw0752 use of a clock as a test tool - very much a 'What would MacGyver do'
    method of rapidly deploying equipment nearby to solve test problems.
  • tin_xdevs
    tin_xdevs over 11 years ago in reply to Problemchild
    There can be never enough precision instruments. Man with one multimeter knows exactly what is the voltage measurement. Man with two multimeters - have no idea what is actual voltage. So I asked myself how many multimeters can tell you true voltage quest :). Still have two units to repair. I like messing with test instruments, and learning how big boys design them. And what can be better than getting broken one and trying to fix it in way of learning? Have still Model 2000 to repair to complete current Keithley DMMs collection.
  • Problemchild
    You could probably string up a little something on a bit of Vero or similar  have a cheap FM module or even a few transistors and make  an AM/FM Radio then a cheep 386 for an Audio amp  have some jumpers going into the amp so you could choose your source etc. All cheap quick and dirty whilst been a learning tool for the "new players".
  • Problemchild
    Problemchild over 11 years ago in reply to tin_xdevs
    Yeah agreed, I must have 3 precision ones and the same again basic ones so I really don't know what any voltage is image
    Nice to see you are spending time to repair them..I bet you are learning loads... Have you checked out Dave Jones' EEVBlog he does a lot of equipment videos  or Signal Path as an alternative
    shabaz over 11 years ago in reply to Problemchild
    That's not a bad idea, Radio Shack/Tandy used to sell a test amplifier with small speaker based on an LM386 too, the high gain on that chip is useful for test purposes! I think some logic probes had an audio output too (another fun project I guess!).
  • Problemchild
    Yeah a whole group of little projects like that could make a nice series of instructional blog  posts
    You're on, we could investigate a joint audio test amp or simplified probe project, hopefully these are quick things, which is always good!
