Test & Tools
Test & Tools
Forum pulse signals - 2 wire and 3 wire
  • Subscribers 384 subscribers
  • Views 1135 views
  • pulse transmitter
  • pu
  • pulse sensor
ngant17
ngant17 over 9 years ago
My current dilemma is how to meter a pulse coming from a  3-wire (Hall-effect) flow sensor and bring it into a 2-wire pulse-transmitter which is plug n' play for 2-wire flow sensors.  Data goes to cloud fairly easily when I keep the 2-wire system.  However the problem is that I don't know how to transmit the current flow into the data signal when working with the two different systems (2-wire & 3-wire).
Commercial flow sensors for water metering tend to be 2-wire, so that's something that isn't going to change.  OTOH lower costs for small scale applications requires that I use the Hall-effect 3-wire flow sensors.  And I still need to keep my wireless gateway and transmitters which are 2-wire.
As you may know, 3-wire Hall-effect sensors are signal, positive, negative.  2-wire flow sensors are red/black, positive/negative.
Do I need to start dropping diodes into a circuit, to make sure current flows are directly one way and I'll get pulse signal instead of noise (and avoid frying the 2-wire pulse transmitters)?
