Test & Tools
Test & Tools
Forum Need Windows USB Driver for TENMA 72-13210 (electronic dc-load 30A/120V 300W)
  • Replies 45 replies
  • Answers 7 answers
  • Subscribers 390 subscribers
  • Views 19796 views
  • tenma 72-13210
  • windows 7
  • windows
  • tenma 72-13200
  • tenma 72 13200
  • tenma 72 13210
  • win7
  • usb-driver
simonwahlmann
simonwahlmann over 8 years ago
Dear all,
does anyone has an idea where to find the "windows usb-driver" for this device?
It's not present on the attached original CD and I also couldn't find it anywhere in the internet.
Thanks for your support!!!
UPDATE 17th of Sep. 2018
Thanks for your replies so far!!!
The device is listed twice at "other devices" when I plug in the usb-port:
     - SZ KORAD USB Mode
    -  SZ KORAD USB Mode
With a CD no driver but a list of commands to control the device is provided.
There is also a Windows executable for a connection test. Its frontend shows three tabs, one for each communication port
     - Ethernet
     - RS232
     - USB
The USB obviously didn't work, because the devices had no drivers installed.
Using an rs232 to usb adapter I was able to control the device via the RS232 port. The device was then listed as "USB Serial Port (COM11)" with an FTDI driver being used.
This might be a workaround but I need to decide whether or not to oder more of these devices. So an inusable usb-port will influence my decission.
I tried out some random usb drivers ending up with an immediate system shutdown.
What else could I try?
  • Gough Lui
    Gough Lui over 8 years ago in reply to simonwahlmann +2
    I have examined the drivers and they are as I expected - just basic INFs to get a USB CDC recognized with Windows' own usbser.sys driver. Unfortunately the ones there have NOT got your VID/PID pair covered…
  • dmxdesign
    dmxdesign over 8 years ago +2 verified
    Hi all i have finally got this all to work after some digging by Devinder from farnell tech suppoprt the zip file a pdf on how to resolve the usb in device manager and a folder with the serial port driver…
  • ayush_1921
    ayush_1921 over 1 year ago in reply to dmxdesign +2 suggested
    found in fernel deep with gui and terminal interface,as it farnell rebrand 3175898.zip
  • Problemchild
    0 Problemchild over 8 years ago
    If it's come from Farnell you could always ask their support
    https://uk.farnell.com/tenma/72-13210/dc-electronic-load-prog-30a-120v/dp/2848407?mckv=rPv7lNfK_dc|pcrid|75247888851825|…
  • rsjsouza
    0 rsjsouza over 8 years ago
    This is quite similar to the Korad KEL-103, but even this model does not have drivers on its website and its manual makes no mention of the USB.
    When you connect it to the host, what kind of device is enumerated? Is it a standard USB-RS232 port from FTDI, Prolific or other?
    If nothing shows up, then it is possible the USB is either non-functional or fictitious. image
  • Gough Lui
    0 Gough Lui over 8 years ago
    It would be good to know what the PID/VID combination of the USB device is. Under Windows, you can find this in the Device Manager in the properties for the Unknown Device under Details (Tab) / Hardware ID (Property). If you have Linux, it may even be better to run lsusb -vv and provide us the results.
    It could be a USB to Serial adapter as many lower-end units may have - depending on which chipset, you might need drivers from FTDI, Prolific, SiLabs, WinChipHead amongst others.
    If it is a "higher end" unit, it could actually be a USB Test and Measurement class device, which will need a VISA layer installed as the IVI driver comes bundled with the VISA layer. You could try National Instruments VISA (NI-VISA), although other VISA implementations are available (e.g. Keysight I/O Libraries, R&S VISA, Tek VISA, etc). Otherwise, it may be possible to use something like pyhon-usbtmc under Linux.
    Unfortunately, without further information such as a programming manual that lists the commands, their format and their values ... it's not going to be easy to get this to work. Ironically, you may end up learning more about the device if it has LXI-compatible LAN, which you can probably learn some details about the commands from. I wonder if there's even anything useful on the supplied CD - but not owning such a unit, I have no idea.
    Maybe if you could list the files on the CD, that could help as well.
    - Gough
  • simonwahlmann
    0 simonwahlmann over 8 years ago in reply to Problemchild
    Thanks for the hint - I'll do that in parallel!
  • simonwahlmann
    0 simonwahlmann over 8 years ago in reply to Gough Lui
    Thanks for your reply!!!
    Well there are two different entries for each of the two devices:
    Device 1 "SZ KORAD USB Mode"
         USB\VID_0416&PID_5011&REV_0200&MI_00
         USB\VID_0416&PID_5011&MI_00
    Device 2 "SZ KORAD USB Mode"
         USB\VID_0416&PID_5011&REV_0200&MI_01
         USB\VID_0416&PID_5011&MI_01
  • Gough Lui
    0 Gough Lui over 8 years ago in reply to simonwahlmann
    From some quick digging, it seems that the PID/VID belong to Winbond/Nuvoton and likely is a virtual COM port:
    0x0416    0x5011    Winbond Electronics Corp.  Virtual Com Port
    It doesn't seem drivers for this are available online - the only reference I found was this Chinese site which needs a login, but if it is USB CDC-class compliant, it should install automatically (similarly to Arduino Leonardo boards). Otherwise, it could be some very small .inf files on the CD-ROM that will be the appropriate drivers - if you can, could you list all the files/explore the CD-ROM? You can do that using the Command Prompt under Windows with the following command (assuming D: is your CD-ROM drive, creating a file called listing.txt in the current directory):
    tree /f D: > listing.txt
    and upload the list here?
    - Gough
  • simonwahlmann
    Here we go - (sorry didn't find a way to attache the text-file)
    I do recognize some visa files...
    BR Simon
    E:\
    ³   72-13210 Communication Commands with Computer.pdf
    ³   USB Driver installation.pdf
    ³
    ÃÄÄÄSoftware
    ³   ³   nidist.id
    ³   ³   setup.exe
    ³   ³   setup.ini
    ³   ³
    ³   ÃÄÄÄbin
    ³   ³   ÃÄÄÄdp
    ³   ³   ³       data.cab
    ³   ³   ³       DevPartDef.xml
    ³   ³   ³       install.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp0
    ³   ³   ³   ÀÄÄÄMU
    ³   ³   ³           MetaUninstaller.msi
    ³   ³   ³           MetaUninstallerR1.cab
    ³   ³   ³           MetaUninstaller_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp1
    ³   ³   ³       EULADep2.cab
    ³   ³   ³       EULADepot2.msi
    ³   ³   ³       EULADepot2_mft.cab
    ³   ³   ³       NIYouLAs.bin
    ³   ³   ³
    ³   ³   ÃÄÄÄp10
    ³   ³   ³       CVI_LowLevelDriverOriginal.msi
    ³   ³   ³       CVI_LowLevelDriverOriginal_mft.cab
    ³   ³   ³       CVI_LowLevelDriverUpdated.msi
    ³   ³   ³       lldrvo.cab
    ³   ³   ³       lldrvu.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp11
    ³   ³   ³       niqpxi32.cab
    ³   ³   ³       niqpxi32.msi
    ³   ³   ³       niqpxi32_mft.cab
    ³   ³   ³       niqpxi64.cab
    ³   ³   ³       niqpxi64.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp12
    ³   ³   ³       NITra00.cab
    ³   ³   ³       NITra01.cab
    ³   ³   ³       NITraceEngine.msi
    ³   ³   ³       NITraceEngine64.msi
    ³   ³   ³       NITraceEngine_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp13
    ³   ³   ³       mDNSResponder.msi
    ³   ³   ³       mDNSResponder_W64.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp14
    ³   ³   ³       NI_Sy00.cab
    ³   ³   ³       NI_Sy01.cab
    ³   ³   ³       NI_SysStatePub.msi
    ³   ³   ³       NI_SysStatePub64.msi
    ³   ³   ³       NI_SysStatePub_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp15
    ³   ³   ³       palerr.cab
    ³   ³   ³       palerr64.cab
    ³   ³   ³       palerri.msi
    ³   ³   ³       palerri64.msi
    ³   ³   ³       palerri_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp16
    ³   ³   ³       NIER_Interface.msi
    ³   ³   ³       NIER_Interface64.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp17
    ³   ³   ³   ÀÄÄÄLVRT_00
    ³   ³   ³           LVRT_00.cab
    ³   ³   ³           LVRT_00_chs.mst
    ³   ³   ³           LVRT_00_deu.mst
    ³   ³   ³           LVRT_00_fra.mst
    ³   ³   ³           LVRT_00_jpn.mst
    ³   ³   ³           LVRT_00_kor.mst
    ³   ³   ³           LVRT_NBFifo_2014.msi
    ³   ³   ³           LVRT_NBFifo_2014_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp18
    ³   ³   ³       niorb.cab
    ³   ³   ³       niorb64.cab
    ³   ³   ³       niorbi.msi
    ³   ³   ³       niorbi64.msi
    ³   ³   ³       niorbi_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp19
    ³   ³   ³       rpcSetup.msi
    ³   ³   ³       rpcSetup64.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp2
    ³   ³   ³       VC2010MSMs_x64.msi
    ³   ³   ³       VC2010MSMs_x86.msi
    ³   ³   ³       VC2010MSMs_x86_mft.cab
    ³   ³   ³       x64.cab
    ³   ³   ³       x86.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp20
    ³   ³   ³       niauth.cab
    ³   ³   ³       niauth.msi
    ³   ³   ³       niauth64.cab
    ³   ³   ³       niauth64.msi
    ³   ³   ³       niauth_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp21
    ³   ³   ³       nicurl.cab
    ³   ³   ³       nicurl.msi
    ³   ³   ³       nicurl64.cab
    ³   ³   ³       nicurl64.msi
    ³   ³   ³       nicurl_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp22
    ³   ³   ³   ÀÄÄÄsvcloc
    ³   ³   ³           nisvcloc.msi
    ³   ³   ³           nisvcloc_mft.cab
    ³   ³   ³           svcloc.cab
    ³   ³   ³           svcloc_chs.mst
    ³   ³   ³           svcloc_deu.mst
    ³   ³   ³           svcloc_fra.mst
    ³   ³   ³           svcloc_jpn.mst
    ³   ³   ³           svcloc_kor.mst
    ³   ³   ³
    ³   ³   ÃÄÄÄp23
    ³   ³   ³       nixerces27_win32.msi
    ³   ³   ³       nixerces27_win32_mft.cab
    ³   ³   ³       nixerces27_win64.msi
    ³   ³   ³       Xerce00.cab
    ³   ³   ³       Xerce01.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp24
    ³   ³   ³       dimSetup.msi
    ³   ³   ³       dimSetup64.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp25
    ³   ³   ³       nipal.cab
    ³   ³   ³       nipal64.cab
    ³   ³   ³       palSetup.msi
    ³   ³   ³       palSetup64.msi
    ³   ³   ³       palSetup64_chs.mst
    ³   ³   ³       palSetup64_deu.mst
    ³   ³   ³       palSetup64_fra.mst
    ³   ³   ³       palSetup64_jpn.mst
    ³   ³   ³       palSetup64_kor.mst
    ³   ³   ³       palSetup_chs.mst
    ³   ³   ³       palSetup_deu.mst
    ³   ³   ³       palSetup_fra.mst
    ³   ³   ³       palSetup_jpn.mst
    ³   ³   ³       palSetup_kor.mst
    ³   ³   ³       palSetup_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp26
    ³   ³   ³       LOGOS00.cab
    ³   ³   ³       LogosXT.msi
    ³   ³   ³       LogosXT64.msi
    ³   ³   ³       LogosXT_mft.cab
    ³   ³   ³       LOGOS_XT.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp27
    ³   ³   ³   ÀÄÄÄLabVI00
    ³   ³   ³           LabVI00.cab
    ³   ³   ³           LabVI00_chs.mst
    ³   ³   ³           LabVI00_deu.mst
    ³   ³   ³           LabVI00_fra.mst
    ³   ³   ³           LabVI00_jpn.mst
    ³   ³   ³           LabVI00_kor.mst
    ³   ³   ³           NIWebServer_LVRTE.msi
    ³   ³   ³           NIWebServer_LVRTE_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp28
    ³   ³   ³   ÀÄÄÄni_error
    ³   ³   ³           ni_error.cab
    ³   ³   ³           ni_error_chs.mst
    ³   ³   ³           ni_error_deu.mst
    ³   ³   ³           ni_error_fra.mst
    ³   ³   ³           ni_error_jpn.mst
    ³   ³   ³           ni_error_kor.mst
    ³   ³   ³           ni_error_report.msi
    ³   ³   ³           ni_error_report_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp29
    ³   ³   ³       activ32.cab
    ³   ³   ³       activ32_chs.mst
    ³   ³   ³       activ32_deu.mst
    ³   ³   ³       activ32_fra.mst
    ³   ³   ³       activ32_jpn.mst
    ³   ³   ³       activ32_kor.mst
    ³   ³   ³       activ64.cab
    ³   ³   ³       activ64_chs.mst
    ³   ³   ³       activ64_deu.mst
    ³   ³   ³       activ64_fra.mst
    ³   ³   ³       activ64_jpn.mst
    ³   ³   ³       activ64_kor.mst
    ³   ³   ³       activex.msi
    ³   ³   ³       activex64.msi
    ³   ³   ³       activex_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp3
    ³   ³   ³   ÀÄÄÄVC2008MSMs
    ³   ³   ³           VC2008MSMs_x64.msi
    ³   ³   ³           VC2008MSMs_x86.msi
    ³   ³   ³           VC2008MSMs_x86_mft.cab
    ³   ³   ³           x64.cab
    ³   ³   ³           x86.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp30
    ³   ³   ³       ni_ssl.msi
    ³   ³   ³       ni_ssl64.msi
    ³   ³   ³       ni_ssl_mft.cab
    ³   ³   ³       ssl.cab
    ³   ³   ³       ssl64.cab
    ³   ³   ³       ssl64_chs.mst
    ³   ³   ³       ssl64_deu.mst
    ³   ³   ³       ssl64_fra.mst
    ³   ³   ³       ssl64_jpn.mst
    ³   ³   ³       ssl64_kor.mst
    ³   ³   ³       ssl_chs.mst
    ³   ³   ³       ssl_deu.mst
    ³   ³   ³       ssl_fra.mst
    ³   ³   ³       ssl_jpn.mst
    ³   ³   ³       ssl_kor.mst
    ³   ³   ³
    ³   ³   ÃÄÄÄp31
    ³   ³   ³       tdms.cab
    ³   ³   ³       tdms.msi
    ³   ³   ³       tdms64.cab
    ³   ³   ³       tdms64.msi
    ³   ³   ³       tdms64_chs.mst
    ³   ³   ³       tdms64_deu.mst
    ³   ³   ³       tdms64_fra.mst
    ³   ³   ³       tdms64_jpn.mst
    ³   ³   ³       tdms64_kor.mst
    ³   ³   ³       tdms_chs.mst
    ³   ³   ³       tdms_deu.mst
    ³   ³   ³       tdms_fra.mst
    ³   ³   ³       tdms_jpn.mst
    ³   ³   ³       tdms_kor.mst
    ³   ³   ³       tdms_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp32
    ³   ³   ³   ÀÄÄÄMDF
    ³   ³   ³           MDFSupport.msi
    ³   ³   ³           MDFSupport1.cab
    ³   ³   ³           MDFSupport_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp33
    ³   ³   ³       mkl.msi
    ³   ³   ³       MKL2000.cab
    ³   ³   ³       MKL2000_chs.mst
    ³   ³   ³       MKL2000_deu.mst
    ³   ³   ³       MKL2000_fra.mst
    ³   ³   ³       MKL2000_jpn.mst
    ³   ³   ³       MKL2000_kor.mst
    ³   ³   ³       MKL2014.cab
    ³   ³   ³       MKL2014_chs.mst
    ³   ³   ³       MKL2014_deu.mst
    ³   ³   ³       MKL2014_fra.mst
    ³   ³   ³       MKL2014_jpn.mst
    ³   ³   ³       MKL2014_kor.mst
    ³   ³   ³       mkl64.msi
    ³   ³   ³       mkl_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp34
    ³   ³   ³       mxs.msi
    ³   ³   ³       mxs1.cab
    ³   ³   ³       mxs64.msi
    ³   ³   ³       mxs_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp35
    ³   ³   ³   ÀÄÄÄlvrteres
    ³   ³   ³           LV2014rteres.msi
    ³   ³   ³           LV2014rteres_mft.cab
    ³   ³   ³           lvrteres.cab
    ³   ³   ³           lvrteres_chs.mst
    ³   ³   ³           lvrteres_deu.mst
    ³   ³   ³           lvrteres_fra.mst
    ³   ³   ³           lvrteres_jpn.mst
    ³   ³   ³           lvrteres_kor.mst
    ³   ³   ³
    ³   ³   ÃÄÄÄp36
    ³   ³   ³       logos.cab
    ³   ³   ³       logos.msi
    ³   ³   ³       logos64.cab
    ³   ³   ³       logos64.msi
    ³   ³   ³       logos64_chs.mst
    ³   ³   ³       logos64_deu.mst
    ³   ³   ³       logos64_fra.mst
    ³   ³   ³       logos64_jpn.mst
    ³   ³   ³       logos64_kor.mst
    ³   ³   ³       logos_chs.mst
    ³   ³   ³       logos_deu.mst
    ³   ³   ³       logos_fra.mst
    ³   ³   ³       logos_jpn.mst
    ³   ³   ³       logos_kor.mst
    ³   ³   ³       logos_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp37
    ³   ³   ³       LV2014rtdnet.msi
    ³   ³   ³       LV2014runtime.msi
    ³   ³   ³       LV2014runtime_mft.cab
    ³   ³   ³       lvrte.cab
    ³   ³   ³       lvrtenet.cab
    ³   ³   ³       lvrte_chs.mst
    ³   ³   ³       lvrte_deu.mst
    ³   ³   ³       lvrte_fra.mst
    ³   ³   ³       lvrte_jpn.mst
    ³   ³   ³       lvrte_kor.mst
    ³   ³   ³
    ³   ³   ÃÄÄÄp38
    ³   ³   ³       MStudioCW3DGraph.cab
    ³   ³   ³       MStudioCW3DGraph.msi
    ³   ³   ³       MStudioCW3DGraph_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp4
    ³   ³   ³       SigningCA.msi
    ³   ³   ³       SigningFakeFeature.msi
    ³   ³   ³       SigningMain.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp5
    ³   ³   ³       LegacyGPIBVXI.msi
    ³   ³   ³       LegacyGPIBVXI1.cab
    ³   ³   ³       LegacyGPIBVXI_chs.mst
    ³   ³   ³       LegacyGPIBVXI_deu.mst
    ³   ³   ³       LegacyGPIBVXI_fra.mst
    ³   ³   ³       LegacyGPIBVXI_jpn.mst
    ³   ³   ³       LegacyGPIBVXI_kor.mst
    ³   ³   ³       NIVISAruntime.msi
    ³   ³   ³       NIVISAruntime1.cab
    ³   ³   ³       NIVISAruntime64.msi
    ³   ³   ³       NIVISAruntime641.cab
    ³   ³   ³       NIVISAruntime_chs.mst
    ³   ³   ³       NIVISAruntime_deu.mst
    ³   ³   ³       NIVISAruntime_fra.mst
    ³   ³   ³       NIVISAruntime_jpn.mst
    ³   ³   ³       NIVISAruntime_kor.mst
    ³   ³   ³       NIVISAruntime_mft.cab
    ³   ³   ³       visasc32.cab
    ³   ³   ³       visasc64.cab
    ³   ³   ³       VisaSharedComponents32.msi
    ³   ³   ³       VisaSharedComponents64.msi
    ³   ³   ³       VisaSharedComponentsWrapper32.msi
    ³   ³   ³       VisaSharedComponentsWrapper64.msi
    ³   ³   ³
    ³   ³   ÃÄÄÄp6
    ³   ³   ³   ÀÄÄÄsslLVRTE
    ³   ³   ³           sslLVRTE.cab
    ³   ³   ³           ssl_LVRTEsupp.msi
    ³   ³   ³           ssl_LVRTEsupp_mft.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp7
    ³   ³   ³   ÀÄÄÄNI_De00
    ³   ³   ³           dep_framework.msi
    ³   ³   ³           dep_framework_mft.cab
    ³   ³   ³           NI_De00.cab
    ³   ³   ³
    ³   ³   ÃÄÄÄp8
    ³   ³   ³       rpcSetupLVRT.msi
    ³   ³   ³
    ³   ³   ÀÄÄÄp9
    ³   ³           KillBit.msi
    ³   ³           KillBit64.msi
    ³   ³           KillBit_mft.cab
    ³   ³
    ³   ÃÄÄÄlicense
    ³   ³       Apache 2.0 License - English.pdf
    ³   ³       Boost 1.0 License - English.pdf
    ³   ³       BSD 3-clause License - English.rtf
    ³   ³       Code Project Open License - English.rtf
    ³   ³       CryptoPP 5.6 License - English.pdf
    ³   ³       FreeType License - English.txt
    ³   ³       GNU Lesser General Public License 2.1 - English.rtf
    ³   ³       IVI Foundation Inc License Agreement - English.rtf
    ³   ³       LLVM License - English.rtf
    ³   ³       MARS 1.0 License - English.pdf
    ³   ³       MD5 Message Digest Algorithm License - English.rtf
    ³   ³       Microsoft Limited Public License MSDN - English.rtf
    ³   ³       Microsoft Platform SDK Server 2003 SP1 License - English.rtf
    ³   ³       Microsoft Public License_license.pdf
    ³   ³       Microsoft Windows Driver Kit License - English.rtf
    ³   ³       MIT 1.0 License - English.rtf
    ³   ³       MIT-X License.rtf
    ³   ³       MIT-X YAJL Style License.rtf
    ³   ³       Mozilla Public License 2.0.rtf
    ³   ³       NI Released License Agreement - English.rtf
    ³   ³       NI Released License Agreement - French.rtf
    ³   ³       NI Released License Agreement - German.rtf
    ³   ³       NI Released License Agreement - Italian.rtf
    ³   ³       NI Released License Agreement - Japanese.rtf
    ³   ³       NI Released License Agreement - Korean.rtf
    ³   ³       NI Released License Agreement - Simplified Chinese.rtf
    ³   ³       NI Released License Agreement - Spanish.rtf
    ³   ³       NICTA 1.0 License - English.pdf
    ³   ³       OPC Classic COM License - English.pdf
    ³   ³       OpenSSL 1.0 License - English.pdf
    ³   ³       STLPort 1.0 License - English.pdf
    ³   ³       UPX 1.0 license - English.pdf
    ³   ³       WordNet 2.1 License - English.txt
    ³   ³       wxWindows 3.1 License - English.pdf
    ³   ³       zlib License - English.pdf
    ³   ³
    ³   ÀÄÄÄsupportfiles
    ³           customResource0009.dll
    ³           merged.cab
    ³           niPie.exe
    ³           nistdtrans0007.mst
    ³           nistdtrans0012.mst
    ³           nistdtrans0017.mst
    ³           nistdtrans0018.mst
    ³           nistdtrans2052.mst
    ³           nistdtransbase.mst
    ³           updateInfo.xml
    ³
    ÀÄÄÄTest Command
            72-13210.exe
  • Gough Lui
    It looks like mostly an old version of NI-VISA but hey - at least the 72-13210 Communication Commands with Computer.pdf and USB Driver installation.pdf look interesting. What do they tell you about installing the driver? I also suspect Test Command\72-13210.exe could be an installer bundle that contains a basic remote control application and driver bundled together (fingers crossed) so could be worth examining.
    Otherwise, do install NI-VISA (probably best from National Instruments directly for the latest/most stable version) and see if the IVI driver picks up your electronic load. If it does, then it will become a USB Test and Measurement Device (IVI) - from my machine:
    While the CD does seem somewhat confusing, don't write it off just yet image. Best of luck.
    - Gough
  • simonwahlmann
    Thanks Gough,
    well
    1. NI LabView 2018 is already freshly installed including all updates an doesn't recognize the device at all.
    2. The "USB Driver installation.pdf" is worthless, because it claims the driver would be on the CD but obviously isn't.
    3. The executable "Test Command\72-13210.exe" is the test-program I metionned in the update of my question and is no installer but really just to test the connection sending the commands described in "72-13210 Communication Commands with Computer.pdf".
    One thing I did recognize at second view of the "USB Driver installation.pdf" is that the driver should be a "nuvoton virtual com port" driver. This is visible on one of the screenshots. Also The OS of the given example is Windows XP. So all in all this is a quiet old description.
    I managed to download such a driver from nuvoton as mentionned here
         NuTiny-SDK-N76E003-V2.1 Virtual COM port issues ? - NuForum
         Driver:
         http://www.nuvoton.com/hq/resource-download.jsp?tp_GUID=SW0520150729202535
    but it didn't work yet.
    Any further ideas?
    BR Simon
    0 michaelkellett over 8 years ago in reply to simonwahlmann
    What does Farnell's tech help say about this - they really ought to be able to come up with something.
    Are you able to try the LAN port ?
    A lot of things default to port 5025 for SCPI commands.
    If the load is any good it's pretty cheap even if you have to buy a USB <-> RS232 converter as well, although you really shouldn't have to.
