Test & Tools
Test & Tools
Forum Anyone Here Using Lascar M-Series Panel Meters?
  • Answers 3 answers
  • Subscribers 385 subscribers
  • Views 1428 views
panelpilotace
panelpilotace over 7 years ago
Hi Guys
Anyone here using one of our M-Series panel meters such as the SGD 28-M? If so, what do you think of it and do you have any feedback for us?
Chris High
Lascar Marketing Team
  • Robert Peter Oakes
    Robert Peter Oakes over 7 years ago +3 suggested
    I am currently using one in my demonstration videos for my Youtube channel Yes they are programmable and have 2 somewhat independent channels but the programming is limited to a few parameters from within…
  • panelpilotace
    panelpilotace over 7 years ago in reply to jw0752 +2 suggested
    Hi John Yes, it's 10M ohms. Thanks Chris High Lascar Marketing Team
  • panelpilotace
    Hi John This is on the latest datasheet which I've sent to Farnell for them to update. Here's the relevant section: Voltage Input The SGD 28-M features 2 voltage inputs, which use a Programmable Gain Amplifier…
    0 jw0752 over 7 years ago
    I looked at the data sheet but it doesn't give the input impedance on the input. Do you happen to know what it is?
  • panelpilotace
    0 panelpilotace over 7 years ago in reply to jw0752
    Hi John
    Yes, it's 10M ohms.
    Chris High
    0 jw0752 over 7 years ago in reply to panelpilotace
    Thanks Chris,
    I also should have asked what the resolution is.
  • panelpilotace
    Hi John
    Voltage Input
    The SGD 28-M features 2 voltage inputs, which use a Programmable Gain Amplifier (PGA) to make the best use of available resolution (the smallest voltage range offers the highest resolution). Each channel can be programmed independently, with the option of eight different input voltage ranges:
    The input voltage range is decided using the two voltages that the user enters in the scaling section of the Panel Pilot software. The software uses the smallest range available, which can accommodate both of the voltages entered by the user. The absolute maximum voltage input is 40V d.c.
    Entering a voltage scale of 0 – 30V in the software will use the 0 – 40V range.
    Entering a voltage scale of 0 – 3V in the software will use the 0 – 4V range.
    Entering a voltage scale of 5 – 15V in the software will use the 0 – 20V range.
    Voltage Range (V) / Resolution (mV)
    0 - 1.25 / 0.3
    0 - 2.5 / 0.6
    0 - 4 / 1.0
    0 - 5 / 1.2
    0 - 8 / 2.0
    0 - 10 / 2.4
    0 - 20 / 4.9
    0 - 40 / 9.8
    Note: V+, IN1 and IN2 share a common ground (i.e. not floating or isolated from each other).
    Rgds
    Chris High
    Thanks for the information. I will check out the data sheet after Farnell gets it updated.
    0 Robert Peter Oakes over 7 years ago
    Yes they are programmable and have 2 somewhat independent channels but the programming is limited to a few parameters from within a theme that you have to select.
    Now there are alot of themes to choose and some even do calculations and provide for instance a calculated POWER given a volt and a current input (External shunt so really 2 voltage inputs)
    Oh, many layouts (Themes) also have touch features like changing screens or clearing alarms.
    What you cant do yet is design your own layouts, only select one of many. but if you want that flexibility there is always the big brother Panel Pilot Ace with 4 ADCs etc and fully programmable including layout design with custom graphics
    Overall nice displays
