Test & Tools
Test & Tools
Forum Connection to DIP package in climate chamber
  • Subscribers 385 subscribers
  • Views 759 views
mich0088
mich0088 over 6 years ago
I would like to connect 18AWG wires to DIP24 socket.
Any suggestion of type of connections other than soldering?
I am thinking of whether to use crimp contact to connect the socket pins, but the diameter of the socket pins are typically 0.51mm.
And most sockets are bigger than 1mm.
Any suggestion?
    dougw over 6 years ago +1 suggested
    You could use a wire-wrap socket which has longer pins. You can bend alternating pins to opposite sides before bending back down. This will provide much more room to solder heavy wire to each pin.
  • msbettyhunt
    msbettyhunt over 6 years ago in reply to dougw +1
    Yes Douglas, the wire-wrap socket is also the best option.
    0 dougw over 6 years ago
  • msbettyhunt
    0 msbettyhunt over 6 years ago in reply to dougw
