Test & Tools
Test & Tools
Forum Using Soldering Station on Voltage Transformers
  • Replies 20 replies
  • Answers 15 answers
  • Subscribers 384 subscribers
  • Views 7093 views
  • ip_iot
ipv1
ipv1 over 6 years ago
Hi all,
I brought my Weller WT1 station from India(220V) over to Canada(110V) and was wondering if one of the online available Voltage Converters would be a good idea?
https://instapark.com/products/itu-1000-series-heavy-duty-ac-110-220v-step-up-down-voltage-transformer-converter-with-us…
The station is 80Watts and I am eyeing a 1000W transformer. So my question?
a. Get the transformer or ?
b. Pay for a new station.(I am considering the Hakko FX888D which I think is a better bet than the Weller WE1010. I know the tenma is a good buy as well but I plan to do some SMD stuff while I am on (forced) leave).
Also if anyone has a pointer to a replacement transformer for the WT1, I'd take that as well.
Thanks y'all.
    jw0752 over 6 years ago +6 suggested
    Hi Inderpreet Since the soldering station isn't that high of a wattage you might find that a small 115V to 220V isolation transformer is all you need. You could even do what you need with an auto transformer…
    dougw over 6 years ago +4 suggested
    You can get a 200W "travel transformer" for $20.
    shabaz over 6 years ago +4 suggested
    Hi Inderpreet, I have this one, it's pretty awful: Image source: google images) it is 100VA, and is for the reverse requirement, i.e. for connecting to 240V to testing things that need 120V. I do not use…
    0 jw0752 over 6 years ago
    Hi Inderpreet
    Since the soldering station isn't that high of a wattage you might find that a small 115V to 220V isolation transformer is all you need. You could even do what you need with an auto transformer with a 110 tapped 220 winding. Though this would not isolate that isn't too important in this application. If you were in the US I would send you one but the rates to Canada from here would probably make it $ impractical. Check out the local electrical contractor to see if they have a used transformer with a sufficient VA to do the job.
    • Vote Up +6 Vote Down
  • ipv1
    0 ipv1 over 6 years ago in reply to jw0752
    That is great advice and I checked local listings. Turns out the transformers are pretty expensive themselves here. https://www.digikey.ca/product-detail/en/triad-magnetics/N-150MG/237-1848-ND/4915262
    The one I listed above is on Amazon delivered for $90 or so.
    What would be the recommended VA for a soldering station though?
    0 jw0752 over 6 years ago in reply to ipv1
    I think you will be better served finding something used that you can use. There is a device called a power conditioner made by PowerVar that is actually a 120 volt to 120 volt isolation transformer for use with home computer systems. By finding one of these used in a computer repair shop or even at an electronics recycling center you can easily make a 120 volt to 240 volt auto transformer that would be more than sufficient for a solder station. If you can find one of these:
    https://www.ebay.com/itm/Powervar-2-0-Power-Conditioner-Model-ABC202-11/153768462764?hash=item23cd5089ac:g:VyYAAOSwncJd~Amd
    You can modify it  to be an auto transformer that would provide the power conversion you need.
    Fullscreen contentimage_206749.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    You can roughly calculate your minimum power need by multiplying the current draw of the solder station by the 220 Volts it is designed to use.  You will be looking for a Powervar that can handle at least this level of power. I am sure that three-phase if he is available could let us know if my advice is in the ball park with respect to the power and VA of the transformer that will be required. The solder station should be primarily resistive in its loading. The Powervar in the above EBay listing looks like it can handle 240 Watts. There may be other sources of similar transformers if you look around. Perhaps one of the guys in Canada would have a suggestion.
    I have one more thing you can do if you haven't already. Take a look at the transformer in the solder station. Manufacturers commonly use transformers that can be wired for 110 or 220 volts as this doesn't affect cost much and it saves having to stock an extra stock keeping unit. Perhaps all you have to do is rewire your present unit.
  • ipv1
    Made me smile image
    Fullscreen 7701.contentimage_206750.html Download
    Going out is not possible so I will keep the ebay listing as a reference. Lemme see if I can talk to the neighbors to see if they have something like that.
    0 dougw over 6 years ago
    Hi Inderpreet,
    For the fun of it I took a toroidal transformer that I had on the shelf with (2) 110 volt primaries and hooked it up as I mentioned before. Here it is with a 110 volt 1.2 Amp input and driving (2) 110 volt 0.59 Amp 75 watt bulbs hooked in series for a 220 volt load. I have just ignored the secondary windings. It has been running on the bench for about 30 minutes and the transformer is yet to even get warm.
    Fullscreen contentimage_206751.html Download
    On the other hand if you can get a 200 Watt travel transformer for $20 that might be the best way to go. I suspect that the ones you can get in Canada will be designed to plug into 220 volts and then deliver the 110 volts needed for the Canadian appliance. You will have to hack the unit and turn things around so that you use the secondary as the primary so that you can convert the 110V mains to the 220 you need for the solder station.
  • gordonmx
    0 gordonmx over 6 years ago
    Have you opened the WT1 case to see how it is wired?  Maybe internally there is a jump or simple component change that can convert to 110V.  Can you ask Welder's customer service people?
    Gordon
    0 jw0752 over 6 years ago in reply to dougw
    Hi Doug,
    You are right here is one that would work for Inderpreet:
    https://www.ebay.com/itm/Delux-200-Watt-110v-to-220v-Transformer-Voltage-Converter-220-to-110-volt-AC200W/122310762890?epid=1128675914&hash=item1c7a4a218a:g:vDUAAOxyY9VRJUQW
    0 dougw over 6 years ago in reply to jw0752
    https://www.ebay.ca/itm/International-Travel-Transformer-110V-220V-220V-110V-60-50Hz-200W-Fused/252468706929?_trkparms=a…
