Test & Tools
Test & Tools
Forum How to calculate the energy in a non uniform pulse wave form between 100usec to 150u sec, amplitude is 10KV
  • Subscribers 384 subscribers
  • Views 343 views
  • in
  • the
  • 150u
  • to
  • uniform
  • pulse
  • non
  • between
  • wave
  • is
  • calculate
  • sec
  • how
  • form
  • amplitude
  • energy
  • a
  • 100usec
  • 10kv?
dsohal
dsohal over 16 years ago
Suggestion is by using oscilloscope and using high voltage probe on one channel, using current probe with suitable shunt to other channel on oscilloscope with the help of Advance analysis module.
Tektronix solution as suggetsed as follows.
Oscilloscope TDS3014C , Farnell o/c 155-4156 ( Any oscilloscope in TDS 3000 series )
High voltage probe P6015A ,Farnell o/c 435-2580
Advance Analysis module, Farnell  o/c 369-3867,
Math Expression Example.
The following expression calculates the energy in a
waveform, where Ch1 is in volts and Ch2 is in amps:
Intg (Ch1×Ch2)
Taking an Area measurement on the resulting waveform
displays the waveform power value.
Please see attached data sheet for scope and advance analysis module for more details.
http://uk.farnell.com/tektronix/p6015a/probe-oscilloscope/dp/4352580?Ntt=4352580
http://uk.farnell.com/tektronix/tds3014c/oscilloscope-dpo-4ch-100mhz/dp/1554156?Ntt=1554156
image071094601web_2008.09.24.11.07.52_13031_EN.pdf
