Test & Tools
Test & Tools
Forum Impedance matching on amplifier input
  • Subscribers 384 subscribers
  • Views 288 views
  • anolog_devices
  • microprocessor
  • knode
  • measurement
ZeroSizeObject
ZeroSizeObject over 15 years ago
If I use a AD8302AD8302 RF gain phase detector with a large resistor (1k) shunt, for power reduction, mess with the impedance matching of the AD8302ARUZAD8302ARUZ? This comes from a 0 impedance of the active band-pass filter output.
The datasheet said to place a 52.3 ohm shunt to match the chip & antenna impedance. Also, inputs are getting signals from a band-pass filter output. Datasheet says, the equivalent input circuit is 3k/2pf at 500mhz and below. I am measuring 500k to 5mhz.
Thoughts?
Zero
