Test & Tools
Test & Tools
Forum Measuring temperature over a large surface
  • Subscribers 385 subscribers
  • Views 668 views
  • analyzer
  • tempurature
  • knode
  • embedded
  • Design
  • measurement
  • sensor
ZeroSizeObject
ZeroSizeObject over 15 years ago
I want to measure the temperature over a large surface. In my case it is a heating coil, but it could really be anything that needs to be measured. I want to get an average of the overall temp. I have 8 10K thermistors, powered by a a remote source, that I will be placing along the coil.
To get an average, would I just wire them in series or parallel? Is the response time an issue with either setup, and which would be the most accurate?
Zero
    Gidday Zero
    Two easy ways , temperature crayons that melt at different tempratures, talk to your local boilermaker to locate the crayons.
    Alot of tansistors measured voltage drop will vary with temperature, I use this into a small amp to drive a meter for a cylinder head temperature gauge on a engine. All driven from a small 9v battery,  works a charm.
    Regards Don
