Test & Tools
Test & Tools
Forum Test Board for Amplifying Bipolar Pulse from Arbitrary Function Generator?
  • Replies 23 replies
  • Answers 4 answers
  • Subscribers 388 subscribers
  • Views 5480 views
  • amplifier
  • amplifying_pulses
  • arbitrary_function_generator
  • high_voltage_pulse
JRR
JRR over 15 years ago
My electronics knowledge is limited, so I am framing my question with the information I have.  I am not sure if I am in the right forum to post this question, so if I am very off, please guide me in the right direction.
I want to find a test board /chip combination to amplify a bipolar waveform.  The reason I want to try a board is because if I find the right one, and it works for my application, at the end of the day, I will be a step ahead with the amplifer electronics I need.  I've also looked at amplifying test equipment that could cost as much as US$2,500.  I could probably test 100 different boards with that much money, which I don't have eitherway.
Here is the description of my project, what I already have, including some of the equipment and information:
Equipment I already have:
- USB powered Osciloscope/wave generator combo product, which has an arbitrary wave generator.  The specs for the wave generator are here:
  Syscomp CRG-101 Datasheet
  It works pretty well, but I realized I need more power for my application.
Application:
- Electrokinetics to move fluid though a wet porous material (the Resistance of my electrode system is below)
What my function generator puts out (from the datasheet above):
- Square pulse
- Max. pulse amplitude 6 Vpp
Description from the pulse I need:
- Square pulse, bipolar
- Frequency between 1Hz&100kHz (I might need something close to DC, and then some at AC)
- Amplitude: 100 Vp-p
- the resistance of my system is below
- I don't need the pulse to have very high resolution / precission
Description of the characteristics of my system:
- Resistance has ranges between (given by my material and my electrode geometry)
  1. Wet = 10kOhm
  2. Semiwet = 100kOhm
Some information I have already looked at but have not fully understood:
- The waveform generator vendor's recommendations for amplification:
   Increasing output current from Signal Generator (Syscomp)
- The two sets of product descriptions I have been browsing (not all have test boards) :
   1. Analog Devices High Voltage Amplifiers
   2. Analog Devices High Supply Voltage Amplifiers
So Finally the question is:
- If you had to pick a testboard/chip combination that met my requirements, which one should it be?
Thank you very much in advance,
J.
    michaelkellett over 15 years ago +1
    If you could live with a reduced frequency range I would suggest that an audio amplifier might be a cheap way round your problem. Farnell owned CPC sell a DA500 power amplifer for £99 which should be able…
    michaelkellett over 15 years ago in reply to JRR +1 verified
    Hello - look up all you can on National Semiconductor's LME49830. None of the AD parts in your references will do but the LME49830 can meet your spec. NS give a pcb layout in the data sheet - you can buy…
  • RWM
    RWM over 15 years ago in reply to JRR +1 suggested
    In fact, LME49830 without output MOSFET stage would be sufficient (as it has 47mA minimum output current, page 5 in http://www.national.com/ds/LM/LME49830.pdf ), but amp module will be easier to use. Alternatively…
  • D_Hersey
    0 D_Hersey over 12 years ago
    I'm old  'n rusty, now the echoplexor I mistake for a mind tells me that the classical amplifier for physics students was/is manufactured by McIntosh.
    just an idea that may make it easier for you,
    get a cheep amp module and put it backwards thru an old style transformer plug pack (AC out or remove the cap and diodes of a DC one)
    you may have a few impedance matching problems and not get real good efficiency but should give you something to work with
    as a cheep option.
  • clem57
    0 clem57 over 10 years ago
    Great reading.
