Test & Tools
Test & Tools
Forum ULTRA low load capacity scope probe ?!?!
  • Replies 7 replies
  • Subscribers 387 subscribers
  • Views 1566 views
dk30713
dk30713 over 14 years ago
I need to measure some vary fast digital signals, and see their individual timing,
so I got plenty of signal level resolution, but want scope probles who do not load the signal with 10pF
this is not good when signals are in nS speeds !
any one know where to get specially designet scope probes with VERY low capacity loading ??
    If you have a couple thousand dollars to spend a Tek P6150 is amazing <0.15pF expect there are cheaper probes available, or buffer the signals using FETs
  • dsohal
    0 dsohal over 14 years ago
            Regarding ultra low capacitance probe In the Tektronix range , I found probe , which is 3.9pf ,500Mhz, Tektronix "TPP0500", other one is TPP1000, 1GHz, and loading of 3.9pf.Please see attached web link http://www.tek.com/passive-probe
    Let me know, if it is not right one.
    Thank you,
    Devinder Sohal,
    Farnell technical,
  • dsohal
    0 dsohal over 14 years ago in reply to dsohal
    It  all depends on which scope  is using. The TPP1000 (3.9pF) is only compatible  with DPO/MSO4000B and DPO/MSO5000.
    Other  alternatives might be the P6158 Low capacitance probe (1.5pF) http://www.tek.com/datasheet/20x-low-capacitance-probe
    Or  the TAP1500 Active probe (<1pF)
    There  are other solutions depending on scope used.
    Thank you,
    Devinder Sohal,
    Farnell technical,
  • dk30713
    0 dk30713 over 14 years ago in reply to dsohal
    thanks alot, I guess active probes add delay to the signal,
    but offcourse if I use 4 of the exactly same probes the delay should be the same,
    and therefore not jamm my important measurements.
    I prefer passive probes, and will see what exist, the scopes we use are from Agilent MSO-X 3054A
    with standard 10:1 probes, they load with 11pF !!
  • Nigelbentley
    0 Nigelbentley over 14 years ago
    I would try the Tektronix Probe selector http://www1.tek.com/Measurement/programs/advisor/
    if they need more information or a faster answer send your question to our IB-EMEA-Support  mailboxib-emea-support@tektronix.com
    I don't know how fast your signals are but I have had great sucess using the Tek P6139A 500MHz probes.  They are a litte higher in capacitance at 8pF but have worked for me.
  • dsohal
    0 dsohal over 14 years ago in reply to dk30713
        You have choice Tektronix P6158 (o/c 390-8574) , according to Tektronix , it will work on any oscilloscope and there are Agilent probes has similar specifications,N2874A ( our o/c 8690693  ),other one is N2876A our o/c 1903994, capacitance is 1.7pf and 2.6pf .
    Agilen tweb link for full details  http://www.home.agilent.com/agilent/product.jspx?nid=-34025.898996.00&cc=GB&lc=eng
    http://www.home.agilent.com/agilent/product.jspx?nid=-34025.898985.00&cc=GB&lc=eng
    Thank you,
    Devinder sohal,
    Farnell technical
