Test & Tools
Test & Tools
Forum Lasers?
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 387 subscribers
  • Views 2089 views
Lasers?
bradnorwood
bradnorwood over 11 years ago
Is anyone in this group familiar with lasers?
  • kas.lewis
    kas.lewis over 11 years ago in reply to Robert Peter Oakes +1
    Peter, Not only would you need to get them to line up exactly in 3D but you would need there phase to be exactly 180 degrees out of phase at that exact spot and every place after that as well, that if…
  • kas.lewis
    I would say so, unless you were doing this in fiber but it sounds like this is all in open air.
  • D_Hersey
    D_Hersey over 11 years ago +1
    Just asking, what about a projection hologram of a cylinder, would that achieve the effect you desire? Also, when one reads a book on T-lines, at the end, they say something like this only describes the…
  • michaelwylie
    0 michaelwylie over 11 years ago
    Yes.
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to michaelwylie
    Is there any type lasers that interupt another lasers focal point preventing it to broadcast further like smoke or fog does?
  • michaelwylie
    0 michaelwylie over 11 years ago in reply to bradnorwood
    You want to stop the propagation of one laser beam in free space by using a second laser beam?
  • bradnorwood
    Yes!
  • michaelwylie
    Does the second laser beam also have to stop at the focal point, or can it continue propagating?
  • bradnorwood
    Either would be useful I'm sure, would both ways be possible?
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to bradnorwood
    I seem to be having an issue with my horizontal and vertical on this side of the pond if I delay.
  • michaelwylie
    I'm not sure what your asking for can be done with two lasers. Even if you could cause destructive interference at exactly a single point in free space, the original beam would still propagate after that point.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago in reply to michaelwylie
    I love Lasers… there great fun but I’m not sure if you will be able to stop one in its tracks like that, you can get them to interfere with each other for cool effects but not terminate the beam, plus the alignment would have to be exceptional even to get them to hit the same spot in 3 dimensional space
  • kas.lewis
    0 kas.lewis over 11 years ago in reply to Robert Peter Oakes
    Peter,
    Not only would you need to get them to line up exactly in 3D but you would need there phase to be exactly 180 degrees out of phase at that exact spot and every place after that as well, that if my understanding of the situation is correct. Either way this would be nearly impossible to pull of when taking into account alignment, laser dispersion and that you want it to be invisible from that point onwards...
