Test & Tools
Test & Tools
Forum Capture Inside and Outside Temp, DC Voltage
  • Subscribers 385 subscribers
  • Views 645 views
We are looking at trying to capture both Inside and Outside building temp, and DC Voltage of a battery bank.
Is this possible with the Raspberry PI 2, to do all three or do we need to do it on three different PI's?
If possible, is there a code sample somewhere?
THanks,
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    I just happen to have posted a video on a very similar circuit http://www.element14.com/community/community/raspberry-pi/blog/2015/04/20/raspberry-pi-2--configuring-for-io--gpio-i2c-spi-and-one-wire You…
  • clem57
    0 clem57 over 11 years ago
    It is possible to do all things on same Raspberry Pi 2. The code will depend on which sensors you choose and wheather they use SPI or I2C interfaces.
    Clem
    0 Robert Peter Oakes over 11 years ago
    You can connect two one wire sensors and the ADC can measure several different things if needed. Resistor divider networks may be needed depending on the battery voltage of course
    Peter
