Test & Tools
Test & Tools
Forum What is EF measurement in a multimeter?
  • Answers 2 answers
  • Subscribers 384 subscribers
  • Views 21570 views
  • ef
  • didigal multimeter
javagoza
javagoza over 5 years ago
I was reading the user manual for this multimeter, MULTICOMP PRO MP730001MULTICOMP PRO MP730001, https://www.farnell.com/datasheets/2819202.pdf   and I don't really understand the function.
What is it for? In what situations is this function necessary?
  • rsjawale24
    rsjawale24 over 5 years ago +7 suggested
    From the datasheet I could understand that it is a non-contact method to detect AC voltages as it uses only 1 probe for measurement. The EF could stand for "Electric Field". EDIT: Typical application could…
    Jan Cumps over 5 years ago +7 verified
    Yes. You can find house wiring back by touching the wall with the probe tip. It will beep/flash if there is an active utility wire at that location. Here is a video where I use that function with a DMM…
    dougw over 5 years ago in reply to javagoza +4 suggested
    NCV presumably stands for non-contact voltage
  • rsjawale24
    0 rsjawale24 over 5 years ago
    EDIT: Typical application could be to detect concealed electrical wiring and any cuts/breaks in the concealed wiring.
    • Vote Up +7 Vote Down
  • javagoza
    0 javagoza over 5 years ago in reply to rsjawale24
    Thanks! Makes sense.
    0 Jan Cumps over 5 years ago
    Here is a video where I use that function with a DMM:
  • javagoza
    0 javagoza over 5 years ago in reply to Jan Cumps
    Brilliant! Thank you so much Jan Cumps
    So it looks like it is the same as other multimeters labeled NCV. I never bothered to know what those initials mean.
    0 dougw over 5 years ago in reply to javagoza
