Test & Tools
Test & Tools
Forum Suggestions for software to generate arbitrary (arb) waveforms?
  • Replies 15 replies
  • Subscribers 383 subscribers
  • Views 8251 views
  • waveform
  • arbitrary_function_generator
baldengineer
baldengineer over 4 years ago
To avoid the XY Problem, here's what I'm trying to do: I want to generate a repetitive waveform with an occasional glitch. I intend to use it as a demonstration of how oscilloscope acquisition modes, interpolation, and triggers work. So the exact characteristics are yet to be determined. A minimum example would be 10 cycles (with some pre-determined period) with 1 cycle having a glitch (not sure how "big" yet.) A maximum example would be 20 cycles with the glitch where the glitch varies in the waveform. (All depending on available sample memory.)
Off-hand, I'm not aware of any good tools that help automate generating an arbitrary waveform such as that. Ideally, I'd like a CSV export. I'd like the time/voltage as CSV to make it more compatible with various instruments. (Also seems like it'd be useful in simulations?)
Any suggestions? Or what do other people use?
  • Gough Lui
    Gough Lui over 4 years ago +6
    I normally just write something quick in Python or use MATLAB. Judicious use of the csv, math and random libraries may well make it a quick job. Another option is that some AWG vendors have their own…
    shabaz over 4 years ago +6
    Hi James, I find Excel useless at it too : ) It can't handle large datasets. If you want a graphical tool, then a free download of Tektronix ArbExpress will do it : ) You can tell it to generate a…
  • scottiebabe
    scottiebabe over 4 years ago +5
    Lots of good suggestions already. Here is yet another Spice Then you can export the data as a tab delimited file (at least in LTSpice) could always find and replace tab to comma if needed.
    shabaz over 4 years ago in reply to baldengineer
    That's very neat! Excellent that R&S developers had robust enough sanity check in their code to ignore the few text/comment lines at the beginning of the file : )
    dougw over 4 years ago
    Looks like you solved it, but Audacity can export csv if you want an alternative.
    You could also demonstrate the glitch as an audible sound - multimedia glitch.
  • javagoza
    javagoza over 4 years ago
    Another very interesting option is the Wavegen option of Digilent's Waveforms program.
    You can play with it in demo mode even without having a device.
    Here is a very good introduction made by your past self.
    /challenges-projects/element14-presents/workbenchwednesdays/w/documents/4650/workbench-wednesday-18-digilent-analog-discovery-review
    https://youtu.be/0nFFJT1oV34?t=195
    dubbie over 4 years ago
    I've never wanted to make an arbitrary waveform. Is there something wrong with me? Do I need help?
    Dubbie
    michaelkellett over 4 years ago in reply to dubbie
    I've very rarely wanted to and although I have several instruments that can I've never used the feature !
    As Fourier nearly said, "sine waves are enough for anyone"
