Test & Tools
Test & Tools
Forum Top 6 Tools
  • Replies 60 replies
  • Subscribers 383 subscribers
  • Views 14015 views
  • favorite tools
Top 6 Tools
dougw
dougw over 4 years ago
All makers are into tools but which tools are their go-to tools. I tried to analyze which half dozen tools I use most often and came up with a slightly surprising list. Obviously it varies from project to project, but some tools get used consistently more than others. I think it will be interesting to discover what others use.
Which half dozen tools do you use the most?
Here are the ones I came up as my top 6 most used tools - they hint at how much time I spend on 3D printing:
Some notables didn't quite make the list - soldering iron, stereo microscope and power supply (mostly because I don't always use the same supply).
  • robogary
    robogary over 4 years ago +9
    My top tools are a gas grill, spatula , and tongs. Working, building, testing, and fixing stuff makes me hungry. An E14 cooler for drinks next to my lounge chair would make this scene complete :-)
  • colporteur
    colporteur over 4 years ago +7
    Two tools I would add to your list are round-nosed pliers and jeweler screwdrivers. The pliers are ideal for shaping wires and components. Especially for putting loops in the ends of wires. The screwdrivers…
  • fmilburn
    fmilburn over 4 years ago +6
    Maybe it isn’t considered a tool but I use my computer more than anything else - for research, design, documentation, coding, lab instrument display, and so on. Also for distraction from what I should…
    dougw over 4 years ago in reply to shabaz
    Nice tool - if I had a ratcheting crimper, I would use more crimps.
  • Andrew J
    Andrew J over 4 years ago in reply to colporteur
    I’ve never used it for such a purpose, only measuring a dimension.  Perhaps the inner dimension wings might do that.
  • ralphjy
    ralphjy over 4 years ago
    Probably based on the type of projects that I do, but I use my 3D printer a lot.  Much more than a DMM or soldering iron, but less than my calipers or phone.  It seems like I always need a case or mounting bracket - and I use a lot of different camera boards, so I’m always printing tripod mounts.  Recently I’ve been printing adapters for GoPro mounts.
    Of course, as Frank pointed out - I can’t do any projects without the computer.
    • Vote Up +5 Vote Down
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to shabaz
    I use the same darn tool for db-25 etc pins. And I hate the darn thing. They are a pain in tush to use one hand holds the pin, the other hand the wire, and you need another hand to crimp it. Disappointed
    shabaz over 4 years ago in reply to phoenixcomm
    That is a problem : ) My current method is to use side of body/chest or leg to push it. I wonder how it's really supposed to be used though.
    I put heatshrink sleeve on the handles to make it slightly softer for this method : )
    dougw over 4 years ago in reply to ralphjy
    The 3D printer is definitely one of my most used tools, especially if you consider operating time. Relaxed
    dougw over 4 years ago in reply to phoenixcomm
    I use a finiky little insertion tool for DB25 (solder cup pins) or insulation displacement ribbon connectors.
    Jan Cumps over 4 years ago in reply to dougw
    I also use it to document how something looks like when taking it appart, for personal refference. And to zoom into details that the eyes don't see (anymore)
  • Andrew J
    Andrew J over 4 years ago in reply to dougw
    I find myself in a position for wiring quite a few Sub-D connectors with solder cups.  How does this tool work Doug?
    michaelkellett over 4 years ago
    My most used tools are  a bit different, excluding the brain extensions (Computer, calculator, notebook) it's scope, power supply, DMM and logic analyser.
    Current preferred scope (Picoscope 6424E, a Roadtest subject) and power supply (TTi QL564TP). The Picoscope is a good all rounder and it's so much more convenient for writing reports and notes that it's live on the computer. Keysight and R & S both offer PC apps to talk to their scopes but not a patch on the convenience of the Pico. It's front end analogue hardware is not in the same class as a decent Keysight or R & S which can bite from time to time.
    As soon as I pick up something to work on I switch on the power supply and the DMM (the Pico comes on with the computer). I have other DMMs but the Keysight is much the nicest to use.
    The Joker in the pack !
    Logic analysers have rather fallen out of favour since scopes started building them in - or so they claim. I realise now that I have wasted a lot of time over the last 10 years using scope based logic analysers. This one cost about £1250 - a bit more than the option on cheaper scopes, but it comes with 32 channels, over 100 protocol decoders and the software runs on a PC so has access to a huge screen and a keyboard. It's just so much better to use ! The advantage of the scope based LA having synch with the usual scope channels is overplayed - it is handy sometimes but I've not yet hit a situation where it was crucial. (These comments don't apply to the really cheap logic analysers - a scope based one is certainly competetive with those.)
