Test & Tools
Test & Tools
Forum Top 6 Tools
  • Replies 60 replies
  • Subscribers 383 subscribers
  • Views 13999 views
  • favorite tools
Top 6 Tools
dougw
dougw over 4 years ago
All makers are into tools but which tools are their go-to tools. I tried to analyze which half dozen tools I use most often and came up with a slightly surprising list. Obviously it varies from project to project, but some tools get used consistently more than others. I think it will be interesting to discover what others use.
Which half dozen tools do you use the most?
Here are the ones I came up as my top 6 most used tools - they hint at how much time I spend on 3D printing:
Some notables didn't quite make the list - soldering iron, stereo microscope and power supply (mostly because I don't always use the same supply).
  • robogary
    robogary over 4 years ago +9
    My top tools are a gas grill, spatula , and tongs. Working, building, testing, and fixing stuff makes me hungry. An E14 cooler for drinks next to my lounge chair would make this scene complete :-)
  • colporteur
    colporteur over 4 years ago +7
    Two tools I would add to your list are round-nosed pliers and jeweler screwdrivers. The pliers are ideal for shaping wires and components. Especially for putting loops in the ends of wires. The screwdrivers…
  • fmilburn
    fmilburn over 4 years ago +6
    Maybe it isn’t considered a tool but I use my computer more than anything else - for research, design, documentation, coding, lab instrument display, and so on. Also for distraction from what I should…
  • colporteur
    The pliers are ideal for shaping wires and components. Especially for putting loops in the ends of wires. The screwdrivers are a must for me as I use terminals for most of my connections. Happy to see an Exacto knife and side cutters made your list.
    • Vote Up +7 Vote Down
    dougw over 4 years ago in reply to colporteur
    I don't even have a pair of round nose pliers...I'll have to consider that (I do need to make loops and nice bends all the time).
    A screwdriver might have made my list except I don't always use the same one.
  • Andrew J
    Andrew J over 4 years ago
    The only one I would add to yours and Colporteur’s, all of which I use so concur, is a Multicomp Pro crimper.  I’m away on holiday at the moment so can’t take a picture.  The calliper I use is a non-digital one and I also own a micrometer but don’t use that regularly.
  • colporteur
    colporteur over 4 years ago in reply to Andrew J
    Do you find the calipers useful for bending component leads for placement on PCB? I had a tool I got on a PACE soldering course for bending components leads. The jaw wide\th varied as you positioned two points in the PCB holes. It was a great little tool that got lost when I moved from electronics to networking. The calipers might work, I was thinking.
    dougw over 4 years ago in reply to Andrew J
    A good crimper makes it more likely that crimps will be used. My crimpers are not great, so I don't do much crimping.
    Jan Cumps over 4 years ago
    magnifier, 3rd hand, soldering iron, cutter&screwdriver, pen, mobile phone camera
    • Vote Up +5 Vote Down
  • fmilburn
    Maybe it isn’t considered a tool but I use my computer more than anything else - for research, design, documentation, coding, lab instrument display, and so on. Also for distraction from what I should be doing.
    • Vote Up +6 Vote Down
    shabaz over 4 years ago in reply to dougw
    I end up using this one on almost all projects, simply because I use a lot of 0.1" pin headers, so I guess this would make it into my top 6. It works with typical generic 0.1" sockets only (it's not a general-purpose tool for a range of crimps), but works really well.
    dougw over 4 years ago in reply to Jan Cumps
    Good point about the camera - it gets used on every blog, but I do a lot of projects with no corresponding blog.
    dougw over 4 years ago in reply to fmilburn
    Wow - I guess I use a computer on every project too - it is so second-nature I forget I'm using it.
