Test & Tools
Test & Tools
Forum Rigol power supply DP832: make multiple channel on/off (track set) permanent?
  • Replies 10 replies
  • Subscribers 383 subscribers
  • Views 4597 views
Jan Cumps
Jan Cumps over 4 years ago
I have a Rigol power supply: DP832A. Two of the channels can be set to track each other. If you change one channel's voltage, the tracked channel changes too.
There's an additional option: to make the two channels switch on-and-off together. It's accessible via Utility -> System -> 2/2 -> track set -> On/Off.
This will set On/Off sync to on or off.
Problem
Now the question: when the instrument is switched off, it forgets this setting. Is there an option to persist it?
I have put the Power On option to Last: that means that settings (should be) are persisted. It keeps set voltages, limits. But not this setting, it seems.
    michaelkellett over 4 years ago +5
    If I set Power On option to Last my DP832A restores tracking as you would hope after power cycling. Tried it a few times and it always worked. In case it helps mine has software Version 00.01.05 and…
  • Fred27
    Fred27 over 4 years ago +1
    I suspect that your personal experience is about as good a guide to what the options are as anything else you'll find. I doubt you've missed anything. If it doesn't save it, then I suspect that's what…
    michaelkellett over 4 years ago +1
    I have an 832A. I'll try to find time to pl;ay with this in the next few days and report back. MK
  • Fred27
    0 Fred27 over 4 years ago
    I suspect that your personal experience is about as good a guide to what the options are as anything else you'll find. I doubt you've missed anything. If it doesn't save it, then I suspect that's what it's designed to do.
  • Gough Lui
    0 Gough Lui over 4 years ago
    Depends on the supply - I've never used a Rigol, but I do know some supplies refuse to store/restore certain settings on start-up (e.g. R&S) to avoid potentially damaging DUTs, while other (Keysight) are happy to restore even channel on/off state.
    I would probably try to store settings and restore settings to see if that even stores the track/link feature. If it does, then at least that may be a little more convenient. Then maybe see if there is a load preset/settings on start-up (which is how Keysight usually does it). If not, then you're probably out of luck and will need to beg Rigol for a fix.
    - Gough
    0 michaelkellett over 4 years ago
    I have an 832A.
    0 Jan Cumps over 4 years ago in reply to Gough Lui
    There are presets, and it can startup with the last settings.
    This particular option doesn't seem to stick though.
    In case it helps mine has software Version 00.01.05 and serial number DP8B151500029
    • Vote Up +5 Vote Down
  • baldengineer
    0 baldengineer over 4 years ago
    FWIW, I have an earlier DP831 with firmware 1.14. I just checked and Track stays enabled through a power cycle.
    0 Jan Cumps over 4 years ago in reply to baldengineer
    Thanks for checking, michaelkellett and baldengineer.
    I'll first try this again, with a fresh look. With other firmware if I can get a hold of it.
    If it fails, I'll post a video of what I do and what I see happening ...
  • baldengineer
    0 baldengineer over 4 years ago in reply to Jan Cumps
    A think a video would help. Maybe a step getting lost in translation.
    Video, showing that the button-sync option does not persist. (firmware: 00.01.14)
    How to replicate:
    Utility -> System -> Power On: Last
    Press Utility to leave the menu
    Utility -> System -> 2/2 -> Track Set -> On/Of: Enable
    select channel 1, Track On
    switch chanel 1 or 2 On or Off, and the two channels switch On and Off together
    Power cycle, then check
    Utility -> System -> 2/2 -> Track Set -> On/Of: it's back to Disable, did not persist. Buttons don't switch both channels in Track mode
  • baldengineer
    Ah okay! I had a feeling you were doing an extra step that I missed.
    I did not know about the "on/off sync!" I've only used the All On/Off on mine.
    Sadly, just like yours, On/Off Sync is disabled on power-up. Disappointed
