Test & Tools
Test & Tools
Forum What's your favorite through-hole desoldering tool?
  • Replies 42 replies
  • Subscribers 382 subscribers
  • Views 10579 views
scottiebabe
scottiebabe over 3 years ago
I have a $5 solder sucker that is nothing fancy for desoldering through hole components. For occasional use it works well enough I suppose.
There appears to be a number of "fancier" solder suckers on the market like this made in japan model:
There are also some inexpensive vacuum desoldering tools, like:
I don't know if it is total junk or a diamond in the rough...
  • scottiebabe
    scottiebabe over 3 years ago +4
    There also appears to be heated suckers: I didn't know they even existed...
  • Andrew J
    Andrew J over 3 years ago +3
    I use this: https://cpc.farnell.com/duratool/d00672/desoldering-station-uk-eu-plug/dp/SD01384 It works pretty well and I've desoldered lots of stuff off prototype boards to reuse. I think Multicomp…
  • beacon_dave
    beacon_dave over 3 years ago in reply to Andrew J +3
    Perhaps take a look at: /challenges-projects/element14-presents/workbenchwednesdays/w/documents/5300/workbench-wednesdays-37-desoldering-wick-tips-and-tricks-with-superwick?ICID=workbenchwed-episode…
  • scottiebabe
    scottiebabe over 3 years ago in reply to javagoza
    Yes I have similar challenges when using a solder sucker and with the time spent fumbling with the sucker the mounting pad gets cooked...
    I have never used one of those bulb type suckers, very neat!
  • scottiebabe
    scottiebabe over 3 years ago in reply to Andrew J
    The sucker tip is supposed to be heat resistant, and you would only place it on the heat joint momentarily
    They do work okay, but sometimes it is a struggle to get the solder out of a plated through-hole...
  • Andrew J
    Andrew J over 3 years ago in reply to Jan Cumps
    I've tried braid on through hole without much success.  Is the trick flux and then more flux plus a dash more for good luck and one more for the road?
  • Andrew J
    Andrew J over 3 years ago in reply to scottiebabe
    I guess not plastic then.  I don't think mine came with any identifier or whatever - not even sure where I got it from, perhaps part of "my first soldering kit" which was a bit rubbish really but good enough when i started out.  So no idea what temp the tip could withstand.
    Jan Cumps over 3 years ago in reply to Andrew J
    Yes. You "can never use too much flux".
  • beacon_dave
    /challenges-projects/element14-presents/workbenchwednesdays/w/documents/5300/workbench-wednesdays-37-desoldering-wick-tips-and-tricks-with-superwick?ICID=workbenchwed-episode-list
  • beacon_dave
    Teflon usually.
  • scottiebabe
    scottiebabe over 3 years ago in reply to Jan Cumps
    I have used a weller vacuum delsoldering tool before it was nice, you can wiggle the pin around and suck out the solder in the plated hole to break the pin free :)
  • scottiebabe
  • Andrew J
    Andrew J over 3 years ago in reply to beacon_dave
    Good video - ironically, one of my tips flashed up at the beginning, but I hadn't actually seen it.
