Test & Tools
Test & Tools
Forum What's your favorite through-hole desoldering tool?
  • Replies 42 replies
  • Subscribers 382 subscribers
  • Views 10593 views
scottiebabe
scottiebabe over 3 years ago
I have a $5 solder sucker that is nothing fancy for desoldering through hole components. For occasional use it works well enough I suppose.
There appears to be a number of "fancier" solder suckers on the market like this made in japan model:
There are also some inexpensive vacuum desoldering tools, like:
I don't know if it is total junk or a diamond in the rough...
  • scottiebabe
    scottiebabe over 3 years ago +4
    There also appears to be heated suckers: I didn't know they even existed...
  • Andrew J
    Andrew J over 3 years ago +3
    I use this: https://cpc.farnell.com/duratool/d00672/desoldering-station-uk-eu-plug/dp/SD01384 It works pretty well and I've desoldered lots of stuff off prototype boards to reuse. I think Multicomp…
  • beacon_dave
    beacon_dave over 3 years ago in reply to Andrew J +3
    Perhaps take a look at: /challenges-projects/element14-presents/workbenchwednesdays/w/documents/5300/workbench-wednesdays-37-desoldering-wick-tips-and-tricks-with-superwick?ICID=workbenchwed-episode…
    Jan Cumps over 3 years ago in reply to scottiebabe
    Yes, the wiggling does the magic.
  • scottiebabe
    scottiebabe over 3 years ago in reply to Andrew J
    Your famous!
    dougw over 3 years ago
    I have tried a lot of different methods. I tend to try the cheap solder sucker in your first image as a first attempt. After pin removal and sucking as much solder out as possible, I clean up the hole with a hot stainless steel pin. Solder wick is a a last resort for me - it seems to require solder to transfer heat to the braid and it is only hot enough where it is already saturated with solder. Maybe if my wick wasn't so old and oxidized it would work better.
  • Andrew J
    Andrew J over 3 years ago in reply to scottiebabe
    That's the one.
  • kmikemoo
    kmikemoo over 3 years ago in reply to scottiebabe
    I have them all and I'm equally inept with all of them. Laughing  The one above - the soldering pencil / vacuum plunger - is probably the one I use the most.  I've given up completely on the non-heated solder suckers (probably have 4).  The squeeze bulb type used to be the "Go To" until I discovered the unit above.  I've also got a unit like Andrew_J but I rarely pull it out.  Maybe if I had better space management skills I would have room for it on the workbench.  I do fire it up when I'm harvesting components, but seldom otherwise.  Only recently, I've had success with solder braid.  Maybe I just got lucky this time or maybe it's because I got a new tin of flux and wasn't skimping on using it.
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago
    Sidecutters, a regular iron and tweezers to pull the pin out, and wick to clean the hole. Upside down
  • scottiebabe
    scottiebabe over 3 years ago in reply to kmikemoo
    Thank you for sharing your desoldering experiences! Now I am intrigued I only found out just today these heated suckers even exist, perhaps if I find one cheap enough I will have to take a chance on it.
    Jan Cumps over 3 years ago in reply to wolfgangfriedrich
    Yes, if the coponent does not need to be recovered, that's the way to go.
  • baldengineer
    baldengineer over 3 years ago
    The "fancy" Japanese model is definitely the nicest manual solder sucker I have ever used. The build quality is great. And when it works, it works well. However.
    I cannot stand to use it.
    The size is relatively small. And I have an exceptionally hard time actuating the button because of the tool's small size and button placement. I end up with this super-awkward handhold so that my finger or thumb can hit the button. So awkward I can NOT usually position it over the joint as needed.
    I have watched others use it with no issue. So it is entirely a James problem. But I just cannot figure out how a way to hold and use it. This is a shame, because as I said, the build quality is an order of magnitude better than the cheap plastic ones.
    Depending on what I am doing, one option is to use low-temperature Bismuth-based solder. This allows me to remove through-hole components without fully removing all of the solder. Then once the part is out, I can clean it up with a sucker or de-soldering braid.
  • scottiebabe
    scottiebabe over 3 years ago in reply to baldengineer
    Thanks for sharing your experience with the "fancy" sucker.
    I think I really should add some of this low-temp solder to my kit. Is there a big difference between the chipquick alloy and bismuth solder?
    image image
