Test & Tools
Test & Tools
Forum Issue with a tenma-12v- 72-6180A
  • Subscribers 379 subscribers
  • Views 1748 views
e14 Contributor over 3 years ago
I'm a new member if I posted this incorrectly I apologize. My issue is I have a 12v tenma 72-6180A power supply.  The supply shows 3v draw with nothing hooked up? Could this be a bad Volt adjustment potentiometer?
The # on the pot. alpha 10c10k just FYI.
Any help is greatly appreciated and welcomed.
Thank you
    Jan Cumps over 3 years ago
    A supply can show volt when nothing is connected. What happens if you put a voltmeter on the output?
    e14 Contributor over 3 years ago in reply to Jan Cumps
     Thank you for your reply.
    I'll need to test that  post back to you my findings.
    dougw over 3 years ago
    You should be able to adjust the voltage between 1 V and 15 V on this supply.
    As Jan indicates, you can check the accuracy of the power supply meter using another voltmeter.
    DAB over 3 years ago
    You might also want to put the power supply under a low current load.
    Sometimes the open impedance will cause a false reading.
