Test & Tools
Test & Tools
Forum Seeking Feedback - How often have you used a Low Resistance Micro-Ohmmeter?
  • Replies 21 replies
  • Subscribers 383 subscribers
  • Views 4879 views
  • low resistance mirco-ohmmeter
rscasny
rscasny over 2 years ago
If you have the time, I'd appreciate if you voted in this poll. I'd like to get a sense of your need and use of low resistance micro-ohmmeters. Thanks.
  • kmikemoo
    kmikemoo over 2 years ago in reply to rscasny +4
    rscasny Younger me used to use them to measure contact resistance on high voltage switchgear (aka circuit breakers) and transfer switches. Older me uses it to measure rotor and stator winding resistance…
    shabaz over 2 years ago +4
    I can imagine them being extremely handy for measuring electrical contacts, such as relays to examine if they are failing, or for checking the resistance quality of shielding or grounding between different…
    shabaz over 2 years ago in reply to beacon_dave +4
    Interesting use! Maybe the inductance may be an issue, although some meters may be more stable than others. Presumably the industrial meters are more immune to that. Also, some meters may use a slow…
  • manojroy123
    manojroy123 over 2 years ago
    We use micro-ohm meter for testing quality of Through hole plating in PTH double sided PCB.
