Test & Tools
Test & Tools
Forum MP780905 Sound Meter
  • Subscribers 380 subscribers
  • Views 1814 views
  • python
  • technical
  • labview
Prashnat
Prashnat over 2 years ago
Can we communicate MP780905 device with 3rd party software's like Python or LabVIEW?
if yes can i get programmer manual or drives link.
Thank you for your supports.
    dougw over 2 years ago +1
    Aktakom ATE-9051 user manual CEM DT-8852 Wavecom DT-8852 SS-8852 Instruction Manual HT-8852 software
  • misaz
    misaz over 2 years ago +1
    It seems like some OEM model. Using searching some phrases from manual I found PCE-322A with almost the same parameters. If software from Farnell website do not work, you can try here https://www.pce-instruments…
    michaelkellett over 2 years ago
    Probably you can - it seems to communicate by virtual COM port over USB.
    It's not clear from the user manual or data sheet what level of control you get over the meter.
    You will need to ask your distributor for a programming manual or to trawl the internet. Many of the Multicomp branded instruments are sold under other labels and often the documentation for these can be helpful.
    CEM DT-8852
    Wavecom DT-8852
    HT-8852 software
  • misaz
    It seems like some OEM model. Using searching some phrases from manual I found PCE-322A with almost the same parameters. If software from Farnell website do not work, you can try here https://www.pce-instruments.com/eu/measuring-instruments/test-meters/noise-meter-sound-meter-pce-instruments-noise-meter-sound-meter-pce-322a-det_5968459.htm
    They do not provide any library (or I did not find it) and if you need it, you will need to reverse enginner software.
  • Prashnat
    Prashnat over 2 years ago in reply to dougw
    Thank you
  • Prashnat
    Prashnat over 2 years ago in reply to misaz
    Thank you
  • Prashnat
    Prashnat over 2 years ago in reply to michaelkellett
    Thank you
