Test & Tools
Test & Tools
Documents Tektronix waveform monitor WFM2200 3G/HD/SD-SDI Farnell o/c 2100679
  • Author Author: dsohal
  • Date Created: 26 Sep 2012 2:54 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:12 AM
  • Views 724 views
Manufacturer:
TEKTRONIX
Order Code:
2100679
Manufacturer Part No:
WFM2200image
Multiformat, Multistandard PortableWaveformMonitor WFM2200 Data Sheet
Features & Benefits
Portable Instrument that is Ideal for Field Production Setup and
Troubleshooting
Operates with Internal, Rechargeable, and Replaceable Battery Unit;
External Recharger Kit and a Battery Unit for Replacement is Available
as an Option
Two SDI Inputs with Multiformat, Multistandard Support
WFM2200 comes standard with auto-detection of HD/SD-SDI and
multiple Dual Link video formats
Upgradeable to include 3G-SDI (Level A and Level B) format support
with the purchase of an upgrade key (Option 3G)
3G/HD/SD Color Bar and Pathological Signal Generator for
Troubleshooting Signal Paths and Equipment (Note: Option 3G is
required for 3G-SDI test signal generation)
Audio Monitoring with up to 16-channel Embedded AES/EBU Audio
Simultaneous Monitoring Support with Multichannel Surround Sound*1
Display and Flexible Lissajous Display
Independent AES Input and Output for Audio Facility Testing
Ability to Display Waveform of External Reference Signal and LTC Signal
for Quick Diagnosis of the Potential Issues in Sync and Time Distribution
System
Tektronix-patented Diamond and Arrowhead Displays for Color Gamut
Compliance Monitoring
Comprehensive Data Monitoring helps to Quickly Resolve Difficult
Content Quality and Reliability Issues (Option DATA)
Simultaneous CEA708/608 Closed Caption monitoring; Teletext and
OP47 subtitle monitoring
Detect and decode ANC data including AFD, WSS, Video Index,
TSID, V-Chip, Broadcast Flag/CGMS-A, VITC, LTC, and ANC TC
ARIB STD-B35/B37/B39, TR-B22, and TR-B23 support
ANC Data Inspector and SDI Data Analysis display helps troubleshoot
ANC data and SDI data problems
Variety of Monitoring Displays
WFM2200 Data Sheet
Features & Benefits
Troubleshooting
as an Option
System
Tektronix-patented Timing and Lightning displays makes facility
Tektronix web link for details information
http://www.tek.com/search/apachesolr_search/wfm2200
imageWFM2200_Multiformat_Multistandard_Portable_Waveform_Monitor_Datasheet_2PW-27280-3_0.pdf
  • waveform
  • monitor
  • tektronix
  • farnell
  • wfm2200
  • o/c
  • 2100679
  • 3g/hd/sd-sdi
