Test & Tools
Test & Tools
Documents Who wants to see electricity flow?
  • Author Author: bradnorwood
  • Date Created: 17 Oct 2014 11:33 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:56 AM
  • Views 1560 views
  • Comments 9 comments
How can we convert voltage data and amps to a visual?
  • shahjee
    shahjee over 12 years ago
    A voltmeter will display the voltage electricity and an Ameter will show the flow of electricity. We can install data recorder. Is this what you wanted to ask?
  • bradnorwood
    bradnorwood over 12 years ago in reply to shahjee
    No, lets say, we pointed our smart phone camera at a set of low or high current wires and seen a visual of the flow of electricity, identified as a color of light if it's hot or not basically... Maybe could look like el wire but only when it was on so to speak...
  • shahjee
    shahjee over 12 years ago in reply to bradnorwood
    I believe there are devices like, speed guns and heat guns. You point them towards a moving car, you can record the speed, you point the gun towards a furnace, a heat gun can record the temperature.
    The electricity can be checked by  devices, like a clamp, you can record ampere, volt in any wire.
    A multi meter can check voltage, amp and resistance.
    In any cell phone, mobile phone, the flow of electricity is different at different points
  • bradnorwood
    Yeah, I was thinking there is a way, we just need to discover it lol
  • bradnorwood
