Test & Tools
Test & Tools
Documents Who wants to see electricity flow?
  • Author Author: bradnorwood
  • Date Created: 17 Oct 2014 11:33 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:56 AM
  • Views 1565 views
  • Comments 9 comments
How can we convert voltage data and amps to a visual?
  • shahjee
    shahjee over 12 years ago
    A voltmeter will display the voltage electricity and an Ameter will show the flow of electricity. We can install data recorder. Is this what you wanted to ask?
  • bradnorwood
    bradnorwood over 12 years ago in reply to shahjee
    No, lets say, we pointed our smart phone camera at a set of low or high current wires and seen a visual of the flow of electricity, identified as a color of light if it's hot or not basically... Maybe could look like el wire but only when it was on so to speak...
  • vsluiter
    vsluiter over 12 years ago in reply to bradnorwood
    The only way you can do that is by using very thin wires and very high currents. The wires will heat up, and then you can use a thermal camera to see where current is flowing. It might look like a far-fetched solution, but I've used it to find shorts on power lines in densely populated circuit boards.
  • bradnorwood
    bradnorwood over 12 years ago in reply to vsluiter
    Maybe there is a way to see the magnetic energy the wire creates from amperage? I'm just thinking outside the box a little. I think magnetic visual is the way we can see it but there has not been much development on viewing these waves.
  • bradnorwood
    Yes I've seen the sheets, they are a neat way to see the magnetic field of magnets, but this system reminds me of carbon paper, hahaha, I still think there is a way to view the flow, and for t to work like an xray would...
  • vsluiter
    There is some foil that discolors to see magnetic field lines (to inspect magnets), but the magnetic field lines along a wire probably won't discolor these sheets.
    This is the product: http://www.forcefieldmagnets.com/catalog/product_info.php?products_id=101
    Here are examples on permanent magnets: WONDERMAGNET.COM - NdFeB Magnets, Magnet Wire, Books, Weird Science, Needful Things
  • vsluiter
  • bradnorwood
