Test & Tools
Test & Tools
Documents Protocol information for Tenma 72-2550 and Tenma 72-2535, Q&A, window driver
  • Author Author: dsohal
  • Date Created: 12 Mar 2015 9:16 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 8:22 AM
  • Views 7569 views
Please check following, if usb is not working.
Please test the software if USB works well or not?
One more thing to be confirmed with the customer as follows:
After you send commands, there will be a beep. Even there is an error; if you confirm USB works well, please check if there is something wrong with the command, for example, there should not be carriage returns or terminator behind the command *IDN?
Therefore, if there is carriage returns or terminator after you type the command, the error will be caused.
Q;TENMA 72-2550 can be controlled with Matlab software?
A:Yes, TENMA 72-2550 can be controlled with Matlab software, as confirmed by supplier.
imageSeries Protocol V2.0 of Remote Control.pdf
USB driver.zip
imageIM - 72-2685 72-2690 72-2695 72-2700 rev.pdf
  • information
  • 72-2550
  • window driver
  • and
  • tenma
  • for
  • q&a
  • 72-2535
  • protocol
  • praneshr
    praneshr over 8 years ago
    Hello @dsohal,
    From the above query, it is clear that the Response time = 50ms. Also when I set this time less than 50ms, I was not able to set the voltage.
    However I didn't find anything saying Response time in the datasheet.
    Could anyone confirm what does this Response time exactly mean? How does this vary for various Power Supplies?
  • praneshr
    Hello @dsohal,
